So I'm riding around and she starts acting like she's going to die and figured I just didn't clutch/throttle correctly. Drive 3-4 more blocks and she cuts out. Thanks god there were no cars behind me and I was only about 20 minutes from home. The battery screws were tight and the fuses looked good at the time. I call a buddy and he comes to get my key to get my spare battery at my house because I broke down in a shadey neighborhood and didn't want to leave my bike ("You can pry it from my cold, dead hands"). Just before he got back, about 10 minutes later, I try to start her again and she fires right up.
My buddy followed me home and I got there with no problems. Once I was home I checked my battery voltage, sealed battery, and it was at 13 volts. I get back on and ride around the neighborhood, she keeps acting like she wants to cut out and she dies a block from my house after about 10-15 minutes. She acts like she's cutting out when the rpms go up which makes since with more juice flowing through the system. I got her home, checked the fuses and notice that the bottom fuse, the main, was burned and while installing a new fuse I noticed that the prongs that hold the fuse are black when the others aren't. I pulled it off and behind the main fuse the red wire is melted, not the wire insulation(?), looking like someone had soldered it and the fuse holder pieces are charred. With a new fuse in it starts right up. I bet as soon as I go riding, give it throttle and the charging system does it's thing it will happen again.
Is my harness screwed or will a new fuse panel resolve it? I have one on the way from evolution_7, so that's covered. Any common procedure for finding this particular type of falt? My PC, actually my OS, died from a virus a couple of days ago and I have to use library PC's. They only let you use them for a short period of time, so my searching ability is very limited. This being said, sorry for not searching before asking. Any help would be greatly appreciated and I will try to get back here to the library until I get my XP disk in the mail.
Also, I have had to use fuses that are longer than the stock ones because I can't find the older style smaller ones anywhere around here.
