Author Topic: easiest way to rinse out tank  (Read 781 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: October 01, 2007, 09:03:46 AM »
I know there is alot of ways to do this what solution should I use to rinse the rust that is in the tank. should I take the petcock off.......I was thinking of cleaning it out then using must rust and being done with it.....if I swish a rust converter around in there would that work.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: easiest way to rinse out tank
« Reply #1 on: October 01, 2007, 09:26:00 AM »
If you would like your petcock to actually stop the flow of gas in the future, definitely take it off.  Must for Rust will eat it up in no time, ask me how I know...  There's a ton of threads on cleaning out tanks, Phos. Acid (M4R), Molasses, etc. Do a search for some ideas.
The stronger the soultion, the quicker the flash rust after it's cleaned is what I've found.  Have some Acetone handy to wring out and latent water after the final flush.  Then either fill it with gas ASAP or swish some diesel in it to protect.
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
