The 750s did make a fair amount of noise going through the gears. The problem is that everyone defines "clunk" differently! If it shifts cleanly while moving with no of few misses, then it should be ok.
You may just need to do small adjustments, change oil if it has been a while, or pull the clutch apart and clean it.
