wouldnt bigger jets make it run richer? bigger hole = more fuel? Maybe I am just confused.
I was running 110s, as stock, before the build.
After the build, I figured because of the altitude, it would be running rich, (higher altitude, less air, richer mixture).
It ran very lean, so I got sets of main jets from 115 to 135. I was running 135 as it was still running lean untill I changed the clip setting on the needle. After the clip setting change, it was only running rich at 2/4 to WOT. After changing the main jet from a 135 back down to a 125, it's all dialed in.
Make a little more sence now?
