In probably 90% of the time, No they will not interchange. the ring dimensions are normally different, (thickness & width). But that doesn't mean the a set from, say a Yamaha Wiseco piston kit with the same bore as a Suzuki model wouldn't fit the piston. But without measuring ring dimensions and than install on piston and measuring side clearances (ring top/bottom to piston groove clearance) there is no set rule/guide to follow. So to put it straight. Don't do it unless you are desperate and have time to play....
