Author Topic: pipe temp  (Read 2560 times)
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
pipe temp
« on: July 17, 2005, 02:50:41 PM »
Here is a stupid question
Pipes 1 and 2 are hot, 3 and 4 are only warm.
static timed, valves set, points set.  Carbs or not perfect, waiting on kits to come.  I'm planing to by new plugs tommorrow.  Could two missaligned carbs cause colder pipes  ???
Thanks
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline Harry
    • CB500F
Re: pipe temp
« Reply #1 on: July 17, 2005, 03:21:46 PM »
Yes. 3 and 4, eh? Well, sounds like your tap or fuel filter could be blocked, if you have the double-tap outlet setup, and suggests the problem is not coils, timing etc. What bike we talkin´about, you have to be more specific.
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
Offline clarkjh
  • Expert? If only.
Re: pipe temp
« Reply #2 on: July 17, 2005, 03:43:58 PM »
74 550.  Same one in my Avitar
I'm leaning toward a blocked fuel line, swapped plugs and 1 - 2 still heat right up, on the rich side.  3 - 4 cool to the touch, can grip them with the egine running, also should be on the rich side, PO was running WO an air filter.  Just have to wait on the kits.  It sucks having great biking weather and I can't go for a spin.
I'm going to stop working on the bike for the night and RTFM again, as well as ALL the carb stuff I can find.
Thanks
James
SOHC/4 #3328
Offline clarkjh
  • Expert? If only.
Re: pipe temp
« Reply #3 on: July 17, 2005, 03:48:14 PM »
Forgot to add,
twin feed valve,  one side to 1 -2 and one to 3 - 4.
Carbs are 022A
#$%*, goto go switch the fuel lines and see what happens.
James
SOHC/4 #3328
Offline clarkjh
  • Expert? If only.
Re: pipe temp: I'm an IDIOT, problem solved
« Reply #4 on: July 17, 2005, 04:07:07 PM »
Boy do I feel dumb, Didn't think to check the gas level.  only ran about 75 miles.  Now I know when it gets to the point of the reserve, it only seems to feed carbs 1 and 2.
Oh well, now to get the carb kits and see if I can get better mileage.
Idiot of the month nominee
James
SOHC/4 #3328
Offline Bob Wessner
  • "Carbs Suck!"
Re: pipe temp
« Reply #5 on: July 17, 2005, 04:50:57 PM »
Trust me, you are not alone.  ;)
Buffo
Re: pipe temp
« Reply #6 on: July 17, 2005, 05:54:06 PM »
the first time i rebuilt my carbs on my CB750K8 I put the floats in upside down. they went right in...nicely. couldnt figure out why no gas was getting to my carbs. when i put the bowls on it pushed the floats up enough to close them...DUHHH
took the bowls off, fuel came out, put the bowls on...no fuel?  didnt take long to figure out but... ;D
Don
Offline Harry
    • CB500F
Re: pipe temp
« Reply #7 on: July 18, 2005, 04:22:39 AM »
Hey James - your Avatar is not working / no picture (at least not on this side of the atlantic)....
Offline clarkjh
  • Expert? If only.
Re: pipe temp
« Reply #8 on: July 18, 2005, 01:27:41 PM »
I see it, anyone else not able to see it?  Maybe I uploaded it wrong.
Also just finish installing the carb kits, jets - 38 and 100, float seats and needle, and main jet needle, and air screws and springs, o-rings and top carb gaskets.  Sinced with a 1/8 drill bit, set the screws to 1 1/2 turns, installed inline fuel filters (the tank filter was full of holes).  Installed new plugs. Started right up and all four are hot.
James
SOHC/4 #3328
Offline Bob Wessner
  • "Carbs Suck!"
Re: pipe temp
« Reply #9 on: July 18, 2005, 01:29:10 PM »
Sorry, still no pic there.
Offline Zeke
Re: pipe temp
« Reply #10 on: July 18, 2005, 02:10:16 PM »
You probably linked the pic to your C: drive instead of uploading it to the sohc server try again.
Zeke
