So here's my current plan of attack, in loose order:
-continue to rip out the stringers and clean up the old glass/resin smegma
-ponder what to do with my transom
-rip out the flooring crud up in the bow
-ponder some more about my transom
-construct some sort of protable drydock hull support system
-ponder even more about the transom
-construct some hull supports (bracing across the top) to maintain the shape when/if I (probably) tear out the transom
-(probably) tear out the transom
-clean up the last of the cruddy supports, braces, blocking, etc.
-now I should have just a hull & deck
-dry, dry, dry...
-fab up & dry fit all of the new stuff; (transom), stringers, floor, bow & deck supports, etc
-resin the crap out of everything (especially the edges), probably at least two coats?
-dry fit the finished stuff just to make sure
-wait for a break in the weather and start to glass everything in...
...but that's pretty far ahead. I like the idea of adding floatation foam, but I really don't like the thought of under the floor. I've been thinking about in the back behind the transom inside the two end 'wings', and in the front bow/floor box thing:
because that shouldn't get too wet and it should drain out pretty good as it's on the front 'slant'. I also like under the gunnals, but I'm thinking I would want to add some conduit there first and that's where all of the control cables, wiring, etc goes and it may be more of a mess and in the way than I want. Besides, wouldn't I have to flip her over to do that?
