Author Topic: Oil in the stator?  (Read 2575 times)
vacafe
Oil in the stator?
« on: July 18, 2005, 11:14:07 AM »
I recently had some charging issues and replaced my stator, rectifier, regulator, and wiring harness.  I pulled the left cover off to install the newly rebuilt stator and noticed there was oil in the cover?  Is the crank seal shot or is there suppose to be oil coating the stator?  The manual says nothing about it.
Thanks--vacafe
Offline kghost
Re: Oil in the stator?
« Reply #1 on: July 18, 2005, 11:16:59 AM »
Yes there is supposed to be oil there, at least on the 750
Stranger in a strange land
vacafe
« Reply #2 on: July 18, 2005, 11:26:44 AM »
Thanks kghost!  Is there a reason why?  Most of the bikes I've worked on had dry stators.  Is there a vent where it comes from in the case.  Just trying to learn more.
Thanks--vacafe
eldar
« Reply #3 on: July 18, 2005, 02:13:43 PM »
O doubt it is for performance but more likely to povide a light coat to protect the stator from corrosion.
Offline kghost
« Reply #4 on: July 18, 2005, 02:14:22 PM »
I assumed it was for cooling an lubrication of the starter bearing, gear, and clutch.
Keep in mind that some bikes have brushes in the charging system and those will definatly be dry type.
eldar
« Reply #5 on: July 18, 2005, 02:25:00 PM »
That could a be possible. Only a small amount of oil would be required since you would not want to contaminate the whole system.
Offline kghost
« Reply #6 on: July 18, 2005, 02:37:53 PM »
Not a whole lot gets in there.
eldar
« Reply #7 on: July 18, 2005, 03:05:15 PM »
It would be nice if there was some chart that showed about how much there should be.
« Reply #8 on: July 18, 2005, 03:44:45 PM »
Just a guess, really.  But, maybe the 750's dry sump oil system meant positive oil control in the alternator section wasn't of major concern.
Is there a drainback hole in that compartment?  Guess I'll find out soon.  My 750 project has a crack in that cover that leaks oil.
Offline Clyde
« Reply #9 on: July 18, 2005, 06:31:29 PM »
The oil for the LH main bearing goes through this bearing into the alternator side where it lubricates the starter clutch rollers and bearing. The oil should end up in the bottom of the alternator side cover then run down through a hole in the crankcase back to the sump pan where it is returned to the oil tank. There should not be very much oil in the alternator cover at all
SOHC4 #1909
Honda CB750 K0(original and unrestored), K1(in pieces), K2(restored), F1(restored), 76 750a (awaiting restoration), 1966 Honda CB72
Suzuki GT750 1972 (restored), Kawasaki Z1 1973 (restored)
Offline kghost
« Reply #10 on: July 18, 2005, 06:48:23 PM »
That what I recall.
Thanks clyde
