Author Topic: CB550 Cafe Interceptor - Gentleman's Roadster  (Read 465480 times)
0 Members and 11 Guests are viewing this topic.
Offline fastbroshi
  • Puppet
Re: CB550 Cafe Interceptor
« Reply #300 on: June 17, 2012, 07:43:51 PM »
Bravo!  I wonder how much of the power increase was just the carbs?
Just call me Timmaaaaay!!!
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #301 on: June 17, 2012, 08:27:45 PM »
AWESOME VID  love the editing , what software is that?
I put it together in Premiere Pro, but the GoPro has the ability to take continuous pictures at .5, 1, 2, and 5 second intervals. Perfect for time lapse video.
Offline Lamp
« Reply #302 on: June 27, 2012, 11:34:44 AM »
Nice work! I'd almost be afraid to ride something that's nice and well done. How did you wire up your tachometer? I'd love to get something more accurate than my 40ish year old mechanical do-dad.
1972 CB750K, with lots of F-model parts... SOLD
Offline FunJimmy
  • Who you calling
  • Vancouver
CB550 Cafe Interceptor - Cam & Rocker Issues
« Reply #303 on: June 27, 2012, 08:58:38 PM »
Hey kids,
Here's a lesson better learned through someone else's stupidity.
When Web Cam says you need to run hardweld rockers with hardweld cams, you do!
Engine started to get a bit noisy in the valve train and I found a couple rockers way out of spec so I went looking for cause.
This is the result of not running hardweld rockers with the Web Cam hardweld cam.
Needless to say, the cam it toast too.
« Last Edit: August 23, 2017, 01:21:02 PM by FunJimmy »
Offline fastbroshi
  • Puppet
« Reply #304 on: June 27, 2012, 09:15:43 PM »
Wow, I wonder how much power you lost on the dyno because of that?
« Reply #305 on: June 27, 2012, 10:37:30 PM »
FJ...about how many miles did it take to get that bad?
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #306 on: June 28, 2012, 12:43:19 AM »
Not that many.
The Interceptor is a casual rider and doesn't see that much street duty.
Offline brandEn
« Reply #307 on: June 28, 2012, 01:27:23 AM »
Oh no! That sucks. You gonna have that thing ready in a weeks time? Just an FYI Delta camshaft can fix your cam. I just had them repair my WebCam 41 for about $100. They are in Tacoma.
« Reply #308 on: June 28, 2012, 03:58:53 AM »
Tough pill to swallow Jimmy. I've seen this before a bunch of times and it always involves both cam and rockers. The good news is with hardwelded rockers and cam, the surfaces will continue to look new for years.
Offline Doctor_D
« Reply #309 on: June 28, 2012, 06:57:32 AM »
Shhhhh... Delta's a secret!
Fine, cat's out of the bag now.  We use Delta for hard-welding all the time. Reasonably priced, fast and professional.  They also have thousands of cam profiles in their machines, and can make nearly anything.
Anyway, that sucks Jim.  Should be a much stronger ride with all 4 cylinders pulling together.
Take care,
David
1978 CX500
1971 Norton Commando
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #310 on: June 28, 2012, 08:00:29 AM »
Pulled some excellent rockers from a donor motor I’ve been keeping under the work bench and installed a mystery re-grind cam that came with the Yoshimura pistons. The guy claimed that the cam was a Yosh, but being a re-grind, I highly doubt it. Will be interesting to see how it feels though.
Buttoned it all up and pulled the trigger around 1:30AM.
Should have known better Brent. Won’t do that again.
Embarrassed to say that I also discovered the Web Cam was timed one tooth out!
I got the ignition timing and idle issues that plagued us on the dyno resolved too.
Maybe cresting the 50HP mark is doable.  ;D
Offline Doctor_D
« Reply #311 on: June 28, 2012, 12:59:12 PM »
So, if the cam was retarded - so it wouldn't idle without the timing over-advanced, and you'd lost a bunch of lift -- which combined with the ignition timing hurt you on the top end.
I hate to make assumptions, but I think your numbers will be much better.  Depending on which way the cam was out, 50-53rwhp should a reasonable target.
Take care,
David
1978 CX500
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #312 on: June 28, 2012, 03:02:01 PM »
David,
The cam was rotated clockwise (when viewed from the right) by one tooth.
I don’t know if that’s retarded (like the installer) or advanced.
Offline Doctor_D
« Reply #313 on: June 28, 2012, 04:06:24 PM »
If the cam was rotated clockwise, then it opens the valves later and was retarded - by quite a bit.  What's one tooth?  10 degrees?  Normally, a retarded cam moves the HP higher in the power band because the enigne is not working against compression as the exhaust valve closes later than it would have with the cam "straight up."  However, the effective range is about 4 degrees.
If you were retarded one-tooth, you were two and a half  times further retarded than the maximum effective range.  this would cause you to lose a significant amount of cylinder pressure at low rpm's.  Advancing the timing increased the cylinder pressure to the point where it would idle.  Add to that the cam damage...
That's my theory anyway.
Take care,
David
1978 CX500
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #314 on: June 30, 2012, 09:15:49 AM »
So, the good news is that this mystery cam is certainly a performance cam. The specs remain unknown, but it has a solid bottom end and very lively from 7K on up to red line.
Bad news……carb jetting doesn’t feel right anymore.   :(
Offline FunJimmy
  • Who you calling
  • Vancouver
CB550 Cafe Interceptor - More Exploites
« Reply #315 on: July 09, 2012, 11:34:46 PM »
Ok, just back from a two day trip through the North Cascade Hwy and into B.C. with Branden & Wookie and the bike is running like a champ.
With this mystery cam correctly timed and Doctor_D's jetting, that 48.8 HP is in my rear view mirror, Baby!
See for yourself.
<a href="
Not a valid vimeo URL">Café Clips - Honda CB550F & CB750 - North Cascade Hwy, WA[/url] from FunJimmy on Vimeo.
« Last Edit: August 23, 2017, 01:22:36 PM by FunJimmy »
« Reply #316 on: July 10, 2012, 05:22:33 AM »
Sounds crisp....nice work there guys. ;)
Offline Greggo
  • Somebody's
  • Helmets Save Lives. Period.
« Reply #317 on: July 10, 2012, 05:35:46 AM »
Sounds amazing Jimmy!  That looks like a great road.
Offline jpklasr
« Reply #318 on: September 28, 2012, 05:34:13 PM »
I just finished reading your build thread after two days. I must say that your fabrication and thought to your bike was mind blowing. I have been working in a machine shop for the last sixteen years as a CNC laser machinist and I saw what you did with a freaking drill press and needless to say, I was very impressed. I have a line on a 79 cb750 and after reading this thread and seeing your awesome bike I am buying it. My shop has 6 Bridgeport milling machines and three Hardigne lathes, not to mention the two lasers that I run and program. Also have press brakes for bending, a 550 lincoln mig and a tig welder, I think I can come up with some cool custom stuff with your inspiration. What an awesome thread. Thank you
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #319 on: September 28, 2012, 05:52:29 PM »
Thanks for taking to time to follow along, and for the kind words.
Good luck & most of all, have fun!
Cheers
FJ
Offline Denotslaer
« Reply #320 on: September 29, 2012, 08:12:23 PM »
Damn Jimmy ! You got skills brother , and an eye for detail !
I have spent a solid 5 hours reading the entirety of this thread and I am in absolute awe , Thanks . With that being said ; I do have a question ... I have noticed a couple of mirror changes . Did you fab the latest , or did you purchase them ? They look fantastic and I am currently in the market for some good ones (not the awful ebay ones for $10) such as yours.
Thanks again for such an informative thread bud !
DENO
"I got rice cookin in the microwave , got a three day beard I don't plan to shave"
1976 CB 750K Cafe Racer
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #321 on: September 29, 2012, 08:53:28 PM »
DENO
Keen eye DENO
Thanks for taking the time to run through the build.
Project bikes are constantly evolving and mine is no exception.
I first started with Napoleon mirrors and quite liked them, but found round Rizoma mirrors on ebay and thought I'd give them a try.
A bit higher quality than the Napoleon's, but the Napoleon's looked more period correct IMO.
« Last Edit: August 23, 2017, 01:30:34 PM by FunJimmy »
« Reply #322 on: September 30, 2012, 06:24:23 AM »
I know why you've got plans to change the front fender FJ. But there is something to be said for a slightly longer fender that keeps the crap out of the engine. That 500 Interceptor job I use is decoration only, twenty feet in gravel with a hot tire..... crap. It's fine if we can pick our weather to ride I suppose.  ;)
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #323 on: September 30, 2012, 11:22:25 AM »
Brent,
That was the thinking and justification for keeping the rear fender too, and I'm glad I did, but I rarely find myself in inclement weather on the Interceptor.
It's all about vanity.
« Last Edit: August 23, 2017, 01:32:00 PM by FunJimmy »
Offline Main Street
« Reply #324 on: October 01, 2012, 10:14:26 AM »
I am very new to all of this but I have been following this when ever I have a few minutes to spare and all I can say is WOW. I'm at the beginning stages and what an inspiration this build is! Just wow
Knees in the Breeze
