Author Topic: CB350F - head gasket replacement  (Read 6421 times)
Offline johnzmg
« on: October 14, 2007, 12:26:19 PM »
I have a low milage CB350F that was recently reborn after setting for 25+ years. It run great after cleaning the tank and rebuilding the carbs but after a couple of long rides an oil leak started at the cyclinder head gasket that has progressively worsened. Plus I'm seeing whitish color smoke from the two exhaust pipes on one side.
The Honda manual indicates replacement of the cylinder head gasket with the engine still in the bike... but it looks really tight.
Has anyone done this job that could offer a few pointers?
Thanks!
John
Offline Jay B
Re: CB350F - head gasket replacement
« Reply #1 on: October 14, 2007, 01:18:51 PM »
It can be done easily with the motor in the frame. I use genuine Honda gaskets, more expensive but worth it, IMO. Take your time and make sure gasket surfaces are clean as can be before reassembly. You might want to do a compression check beforee you tear into it, if it needs more than gaskets, now would be the time to do it.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: October 14, 2007, 02:39:25 PM »
When you have all the head bolts off and the head still won't budge, look again, because you missed a bolt.  And don't pry on the cooling fins to remove the head because they'll break easily.
Offline Short Round
« Reply #3 on: October 14, 2007, 04:35:11 PM »
I agree with gordon.  There is nothing that makes you feel more like an idiot than prying on the fins, breaking one and then realizing that you missed a nut or bolt.  Go slow, recheck everything you do and then proceed.  I have not taken the head off with the motor still in the frame but if your blowing white smoke you want to do a compression test, and also while you have the head off have the valves reseated.  Make sure you use a ton of ziplock bags and lable them as you go.  Good luck and keep us posted......................Chris.
1974 CB550
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #4 on: October 14, 2007, 04:46:42 PM »
        Glad you could make it John. ;) There's a lot of great info, experience, great folks and awesome bikes here. :)
                                Later on, Bill :) ;)
Member # 1969
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #5 on: October 14, 2007, 07:33:07 PM »
Thanks!
John
Hey John, Thats exactly what my 350F did when I got it running again two months ago.  :D Same thing, leaky head... getting worse and white smoke. Bet it runs fine until you wind up the rpm's too.
Anyway, If the head gasket is leaking, a compression check won't be very accurate but will give you an idea. There are also some O-rings you will need when you go to change the gasket and while you're in there, I'd replace the valve seals too. There likely adding to the smoke.
 Matt.
Gallery at:
Offline johnzmg
« Reply #6 on: October 15, 2007, 06:33:17 PM »
Guys, thanks for the information. I would really like this to be as painless as possible so it's good to know I may not need to remove the engine from the frame. I may try to re torque the head as Bill suggested in another post, however, I'm not usually that lucky. I'll probably replace headgasket and also change the valve seals while I'm in there... just cuz.
And Bill, thanks for directing me to this site. Lots of excellent info here.
John
Offline jas67
« Reply #7 on: June 12, 2017, 11:50:09 AM »
I know this is an old topic, but, still relevant.
I've got a CB350F and CB400F that are both seeping oil at the head gasket.    I don't yet have a service manual (shame on me, I've got TWO each of CB350F and CB400F bikes).    Anyway, does anyone have the torque specs and torquing order handy that they can post?
Classic Honda:
1976 CB400F
1975 CB400F (project)
1975 GL1000
1968 CL175 (1 nice one, one project)
1967 CB77
1967 CB160 (2 of 'em, both projects)
1967 CL160 project
Triumph: 2017 Thruxton R
BMW: 2016 R1200RS, 1975 R90S, 1973 R75/5, 1980 R100S
Ducati: 2013  Monster 796, 2013 848 Evo Corse SE track beast, 1974 750GT, 1970 Mk3d 450, 1966 Monza 250
Moto Morini: 1975 (titled 1976) 3 1/2 Strada, w/ Sport clipons.
Moto Guzzi: 2017 V7III Special,  1977 Le Mans, 1974 Eldorado
« Reply #8 on: June 12, 2017, 11:56:20 AM »
Offline jas67
« Reply #9 on: June 12, 2017, 12:38:06 PM »
Thank you!
Classic Honda:
1976 CB400F
1975 GL1000
1967 CB77
1967 CL160 project
