Well, it's steering stem will fit your 72s headstock. It is different than your stock piece though. The holes in the 77 trees for the fork tubes are the same distance apart as your 72s but they are closer (front to back) to the steering stem. This will shorten your wheel base and affect front end geometry. Honda did this to improve handling but the later bikes also had longer swing arms. On the upper section, the holes for the gauge bracketry are likely different and there are provisions for mounting the ignition switch. There will be less rise built into the handlebar mounts. There are also holes to mount up a front brake line splitter on the lower section . . . . .
