SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
tail light won't work
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: tail light won't work (Read 795 times)
professor
Guest
on:
October 16, 2007, 03:50:47 PM »
Get this. My tail light works with brakes but does not work with headlight in the normal on position with headlight. It also works in the lights on position--the second position of on. I replaced the switch having thought that was the problem. Any ideas? Each length of wire I check says it gets power.
Logged
TwoTired
Really Old Timer ...
Re: tail light won't work
Reply #1 on:
October 16, 2007, 04:18:36 PM »
Check you 12v return path. Each electrical consumption device needs two connections to the battery. + 12V is only half the path. You need 12V return, too. Some call it a ground. (though technically, it isn't)
Logged
professor
Guest
Reply #2 on:
October 16, 2007, 04:33:27 PM »
Thanks for the idea. Everything I read says most electrical problems are the ground. I'll try that.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
