They are weird size tapered roller bearings and you can't just buy them over the counter at your bearing dealer.
There are a few kits available. I think some use "mismatched" races and fit together a bit strangely, and some use remachined races or custom races. Regardless, they work well and are in some ways better than the stock ball setup.
I've installed roller sets on bikes that had damaged stock bearings (notchy on centre).
I've repacked a bunch of Honda steering head ball sets. They work pretty well.
If your bearings are good, ie if you lift the front wheel there's no crunchiness or notchiness as you turn lock to lock... I would just clean and repack the ball sets. Installing the roller kit is a bit of a job, and for most of the world the ball setup is all the bearing needed.
If you're bearings are damaged and you're replacing races anyway, go for the roller kit.
