Author Topic: Will a '73 CB750K rear wheel fit a '7 CB550F?  (Read 794 times)
Offline FunJimmy
  • Who you calling
  • Vancouver
« on: October 19, 2007, 05:35:34 PM »
Hi guys
Does anyone know if a '73 CB750K rear wheel fit a '7 CB550F? Axle diameter, etc etc.
I'm considering the purchase of a CB750K rear hub to build up for my CB550F Café project. Seems that the CB550 rear hub that I have is beyond spec for brake drum diameter and I need a better one.
Alternatively if anyone has a CB550 hub for sale, that would be great too.
Thanks
Jim
« Last Edit: October 19, 2007, 05:46:59 PM by FunJimmy »
Re: Will a '73 CB750K rear wheel fit a '7 CB550F?
« Reply #1 on: October 20, 2007, 02:33:10 AM »
Brakes are different and you would need to make spacers.
All 500 & 550 hubs 71 thro 76 are the same 77 & 78 are different, If you were in UK I would send you the adress of a man who re-sleeves the 500 ones
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #2 on: October 20, 2007, 08:26:07 AM »
Bryan
Thanks for that.
The CB750 hub that I'm considering has the brake assembly included and spacers are ok to make. Is the hub larger (and heavier) than a 550 hub? How about axle diameter?
Thanks again
Jimmy
« Reply #3 on: October 20, 2007, 09:06:36 AM »
750 axle is 20mm, I think the hub may be wider and not sure your 500 sprocket can be modded to fit the 750.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #4 on: October 20, 2007, 01:33:58 PM »
Thanks
That helps a lot.
Jimmy
