Author Topic: Putting 2 LED tail lights on my cafe...  (Read 5312 times)
Offline DammitDan
  • Prodigal Son
  • It lives!
« on: October 23, 2007, 11:33:17 PM »
Anyone have any experience with this?  I've searched the forums and have some good leads, but I don't know exactly what I should be looking for...
I'm trying to put 2 projecting LED tail lights sticking out of the back of the frame here...
Any suggestions?  I'm also on a budget, so any lower-priced options would be great.  I'm just looking for tail/brake lighting (maybe connect them for turn signals, too?  if possible...)
CB750K4
del105
Re: Putting 2 LED tail lights on my cafe...
« Reply #1 on: October 24, 2007, 05:30:34 AM »
I don't really have any advice on how to do it, but your visibility is going to be really low day and night with single LED lights. They tend to not be visible at all unless you're directly behind them. I tried using singles as blinkers and no one could see them.
« Last Edit: October 24, 2007, 06:57:00 AM by del105 »
upperlake04
« Reply #2 on: October 24, 2007, 06:55:46 AM »
 Interesting solution for a non-skid seat Dan ;D
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #3 on: October 24, 2007, 07:31:25 AM »
:D :D HHAHAHAHAHAHAHAHAHAHHAHAHAHA>>>>>>>>.......... HEEEEHAHAHAAHAHAHHAAHAHAHAHAA!
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Rooster379
« Reply #4 on: October 24, 2007, 07:31:53 AM »
I'm working on a LED tail light and signals myself at the moment. Being a truck driver I tend to get into a little "trouble" mixing and matching things, but I'll be using a 4" red sealed tail/stop LED light with a quick disconnect pigtail spliced into the factory harness, the mount will be similar to most other cafe seats, in the hump. For turn signals, I've yet to decide, but you could look around on iowa80.com or other truck driver chrome shop sites. just my .02, good luck
Offline rhinoracer
« Reply #5 on: October 24, 2007, 07:33:44 AM »
Check out the new Harleys, they have exactly what you're trying to do.
I'm not good with HD strange names but I think they are the nightster and the latest chopped chopper.
Baja native.
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #6 on: October 24, 2007, 08:13:04 AM »
hahahaha...  That gave me a good laugh this morning, thanks man  ;D
Here's what it looks like with the whole deal installed:
I'm basically looking to have an LED pod that will stick straight out of that hollow frame end, then drill the frame farther back for wires to feed in.  I'm sure I could easily fabricate something that I would glue in there with silicone or liquid nails, but I don't know where I can get the socket from, or what it would really look like.
And I plan to use a 10 or 12 LED pattern bulb, so it should be plenty bright during the daytime.  And I'll have 2  ;D
CB750K4
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #7 on: October 24, 2007, 09:51:42 AM »
Something else to consider is that you can now buy 5 watt LED taillight bulbs.
I put one in the other day and they're bloody bright.  Definitely brighter than a standard light bulb.
http://www.eautoworks.com/html/ORD-1-1-1-113633.cfm
... Course they're not particularly cheap...
Offline Einyodeler
  • Midnight bugs taste best!!!
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #9 on: October 24, 2007, 10:46:20 AM »
Here are a couple of links.
I`ll probably be doing this to the CJ360 rebuild as well.
http://cgi.ebay.com/ebaymotors/2-Red-LED-Brake-Tail-Lights-Go-Cart-Sand-Kart-Off-road_W0QQcmdZViewItemQQcategoryZ46092QQihZ010QQitemZ200134388012
http://cgi.ebay.com/ebaymotors/Red-LED-stop-tail-turn-Lights-Motorcycle-ATV-Trailer_W0QQcmdZViewItemQQcategoryZ34284QQihZ010QQitemZ200135722488
Looks like those housings are going to be too big to fit inside the frame tube.  I measured the tube at 3/4" inner diameter and 7/8" outside diameter...
CB750K4
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #11 on: October 24, 2007, 12:48:52 PM »
I went ahead and ordered these ones...
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?MfcISAPICommand=ViewItem&item=180170175668
When I get them I'll document the installation  :D
CB750K4
Offline johnny
« Reply #12 on: October 24, 2007, 06:44:35 PM »
I use one of these on my 350 tail/brake light.
I can't see why it wouldn't work for your application.
http://superbrightleds.com/specs/115x-xLX3.htm
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline edbikerii
    • Gallery
« Reply #13 on: October 24, 2007, 06:53:26 PM »
I just ordered one for my 550.  How well does yours work for you?  Are you happy with it?
SOHC4 #289
1977 CB550K - SOLD
1997 YAMAHA XJ600S - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline GoatBaSS
« Reply #14 on: October 24, 2007, 07:03:37 PM »
Johnny may have the coolest avitar of the month! ;D
Leethal # 3046?
Offline Patrick
« Reply #15 on: October 24, 2007, 09:25:07 PM »
I got LEDs for another of my bikes from here: http://superbrightleds.com/index.htm
Best prices I've found on the web. I used them to allow me to put additional lights on an old Yamaha without overdrawing the weak alternator.  LEDs can be as brighter or brighter than incandescent bulbs and they also can be seen from all angles, if you get the right ones. You can use them for turn signals, but not with the stock flasher, which has to have a draw on it to work. LEDs draw extremely little juice. With an electronic flasher, though, they can be signals.
Patrick
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Bodi
« Reply #16 on: October 26, 2007, 07:40:35 AM »
Quote:
"Something else to consider is that you can now buy 5 watt LED taillight bulbs.
http://www.eautoworks.com/html/ORD-1-1-1-113633.cfm"
Probably excellent lamps, I use some 3W Luxeon 1157 replacements that are BRIGHT!.
But I worry about their engineering... quote from the website:
(http://www.eautoworks.com/html/ord-Light~bulbs-Signal,Corner,Tail~and~accessories~bulbs-1-113626.htm)
"Automotive LED lights produce more intense light that travels faster and farther then any ordinary automotive light."
Hmmmmmmm.... if they really think they can speed up light, how much can I trust their designers?
Offline dusterdude
« Reply #17 on: October 26, 2007, 01:33:29 PM »
pro teal did somethnig like that on his 750.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #18 on: October 26, 2007, 01:43:07 PM »
True engineers/designers know better.  But, marketing/sales types have always wanted to change the laws of physics, as well as the time continuum. And, THAT'S where trust is unwarranted. ::)
1arm
« Reply #19 on: October 26, 2007, 02:42:15 PM »
I had these Hyperlite 3-way LED modules on my old bike (deceased).  I used them as supplements to stock tail/brake/turn but they should work just by themselves.
Half of each module works as tail/flashing brake and the other half as turn signals.
http://www.casporttouring.com/store/merchant.mvc?Screen=PROD&Product_Code=17002&Category_Code=HYP
Offline edbikerii
    • Gallery
« Reply #20 on: October 26, 2007, 04:03:31 PM »
My Luxeon Lx3 3W taillight came in last night.  It is definitely much brighter than the incandescent 1157.  Visibility day or night won't be a problem, but not having a white bulb to illuminate the license plate might be (at inspection time and maybe at the "end of the month").
SOHC4 #289
1977 CB550K - SOLD
1986 GL1200I - SOLD
2004 BMW R1150R
Offline johnny
« Reply #21 on: October 26, 2007, 08:51:39 PM »
Thanks!
1976 CB550K
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline johnny
« Reply #22 on: October 26, 2007, 08:55:03 PM »
So far, so good. The Luxeon is BRIGHT! Best of all, it only draws 3 watts - which is great for my inadequate charging system. I also just installed a 35 watt halogen headlight assembly - which seems to help keep the drain on the system to a minimum.
1976 CB550K
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline jonbuoy
    • My rebuild:
« Reply #23 on: October 27, 2007, 09:30:31 PM »
Those LED lamps do react faster - there is no bulb filament to heat up.  The difference is surprisingly noticeable.  I think a car manufacturer quoted it as worth a few meters in stopping distance.
