I have a 1 owner '70 750.Very annoying is the plugs loading up in town,then you hit the highway and bap bap bab till the plugs clear.New plugs fix it,for about a day.Sound familiar?I have cured mine and many others by installing projected nose plugs.I use NGK DPR8EA .Depending where you live,also DP8EA,DP8ES is also fine.Fear not problems!My unit is now a RC 1000 and these plugs have caused no trouble after many years.Only exception would be sustained high speed [road racing-Autobahn]Every 750 I have tuned gets them;customers always happy.On a related note,if modifying these old girls does not cause you ulcers;I highly recommend a pointless ign. and better coils.I have a Martek 440,dyna green 3.0 coils,and 8mm silicone jacket solid core wires in the 1000.Dyna makes a good ign. also that I have installed on other units.Every thing your engine should do it will do better.Yes, if you have a failure,you are going home on the trailer,while the points system MIGHT nurse you home.The improved performance more than tips the balance scales ,in my view.
