Ahhhh, the X-pipe has once again reared its ugly head, and all of the downsides have been covered save one. SOME ASSEMBLY REQUIRED!!!!!
Four thin pipes and a collecter, covered in sloppily applied, uncured high temp paint. It is up to you, the unwary buyer, to drill, screw, weld, add springs....whatever it takes to insure that the collector doesn't blow off as soon as you hit the start button.
Looks like it hangs a bit low? Well, that's 'cause it DOES hang a bit low. You'll lose about 1-1/2" of ground clearance under the engine. Probably more since the entire weight(which isn't much actually) is supported by the exhaust collars(as geeto points out). Take a look at the DOHC pic. See how the exhaust doesn't extend out much further than the frame rails? This exhaust hangs SO LOW that the exhaust tip hits ground before the stock foot pegs do.
Still, I am undeterred and as soon as I've run the bike on the dyno I am going to fit the X-pipe for it's trial run (only mounted it to check fitment so far). The down tubes will get wrapped in header tape to hide whatever rust may develop. The centerstand has to come off in order to use this pipe so I will be having a mount made to connect the collector to the center stand frame tabs in order to support/raise the exhaust tips so they don't scrape ground when fully leaned over. And springs will be welded on so that the collector can be removed for oil changes.
The curious side of me just wants to know what this exhaust is really like. The silly/stupid side of me wants to have Terry paint me up some AC/DC "Back in Black" theme bike parts so I can fit this pipe to the bike and call it "The Thunder From Down Under"
OK, just shoot me
Back to the "Benji vs. Kerker vs. Mac" thread. Forget the X-pipe.
