A regular Baskerville he is;)
Can you tell me about your polishing method. A how to primer
Thanks
Well, for the oil filter and the cam tensioner I started with 220 grit sandpaper (not only were they dirty/oxidized they were scratched all over) and moved from there to 500, then 1000, 1500, 2000, 2500, Mothers aluminum polish, and finally Never Dull.
It takes a bit to get the mirror finish, but each level of sanding takes progressively less time. The 220 takes the longest since you are trying to remove any pits, scratches, dents, etc that are there. After that you are just smoothing out the scratches left by the previous layer.
It's quite the process, gives you plenty of time to think about life, the universe and everything
I'm pretty happy with the results, but I think I would like to try using a bench grinder with a polishing wheel on it. as it might make things go a little quicker. I used one once when making a knife (on of my friends father-in-law's makes sword canes).
I'm always on the lookout for quicker methods to clean things up. I'm currently battling a thick layer of grime on the swingarm, frame, and exhaust pipes. For the swingarm and frame I'm not too worried since those are going to be powder-coated, but the exhaust I am trying to be very careful not to damage them any more than they already are.
I'm considering how to clean the engine. It's really bad, I took a razor to it and the stuff came off in chunks. The bottom of the engine is black and oily. How dangerous would it be to take it down to one of those car wash places and use the pressure washers on it. I have the gasket kit for the engine, which after cleaning will be taken apart.
At this time I don't think I can afford to do the 836 kit. After reading around it seams that to do the kit, and get the most bang out of the bike, you really have to redo the ports, exhaust, carb jets, air pods, yada. I think right now it would be best (motivationally speaking) to get the bike running and then work on the 836 kit. I'd like to feel the bike before going through with a major mod like that.
