Author Topic: 1977 CB750k Rebuild or Cafe Racer.... (Lots of Pics)  (Read 27204 times)
ethos42
Re: 1977 CB750k Rebuild or Cafe Racer.... (Lots of Pics)
« Reply #50 on: December 09, 2007, 07:15:43 PM »
Today's update:
Got the engine on the bench and started pulling things off. So far I've got the top-end in peices. I'm very glad I didn't try to start this thing before doing all of this. It's pretty rough in there.
My goal right now is to get the engine taken all the way down to the case. I'll clean, polish, and paint the case, powdercoat the frame and a few other parts. And while all of that is happening, I'll be checking the internals for wear and possible replacement. I am going to replace the majority of the bolts with allen-head bolts.
I found a couple of threads that had been heli-coiled. So I'm going to have to figure out how to deal with those since the threads looks striped.
Here's where I am today:
The Operating Table
A feeble attempt at keeping everything organized.
I can't wait to crack this open:
« Last Edit: December 09, 2007, 07:20:49 PM by ethos42 »
ethos42
« Reply #51 on: December 09, 2007, 07:31:22 PM »
Here's a couple of quick shots of the threads. There's about 4 that look like this. They hold the rocker arm assembly to the cylindar head.
Top View
Side View
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« Reply #52 on: December 09, 2007, 08:07:40 PM »
That almost looks like a heli-coil.  But, you might want to look for another head if you're going to go through all the trouble of a full rebuild/powder/polish etc.
No point having something like this haunting your soul while spinning the cam at 8000 RPM.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
ethos42
« Reply #53 on: December 09, 2007, 11:50:09 PM »
Good point, about how much would one of those run? And does anyone happen to have one?
Also, if I replace the head, what else should I be doing at the same time?
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #54 on: December 10, 2007, 12:57:03 PM »
Dancing  ;D
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline Mossy21
  • It takes "Time" to be a Classic..........
« Reply #55 on: February 08, 2008, 05:58:14 PM »
I have a spare complete head, cleaned up with all valves springs and new stem seals.
Just drop it on.  If your interested, let me know. :)
« Last Edit: February 08, 2008, 06:00:06 PM by Mossy21 »
If I can't see the Engine I can't see the point.......
ethos42
« Reply #56 on: March 06, 2008, 10:11:21 AM »
Sorry for the delay in responding here, I've been tied up with other projects. I'd love to take you up on your offer. Just PM me the details :)
As for now, I'm somewhat stalled on taking the engine apart. I've managed to completely mangle a set of philips head bolts holding the main drive to the engine case. I'll post pictures tonight, and my plan of attack.
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #57 on: March 06, 2008, 10:22:44 AM »
Does your plan include an impact driver? ;D
spwg
Offline dusterdude
« Reply #58 on: March 06, 2008, 12:04:00 PM »
easy fix,tap the hole to the closest size possible,buy a grade 2 bolt long enough to fill the hole,cut the head off,saw a slot in the bolt,put loctite on the bolt and screw it in and let it dry.either take the head to a machine shop or very carefully drill the bolt out with the correct size drill bit and retap the hole.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
ethos42
« Reply #59 on: March 07, 2008, 12:50:38 PM »
Here's a pic of the actual damage:
sometimes I think I should hang up my tools :(
matt365
« Reply #60 on: March 09, 2008, 10:33:17 PM »
I think it's time for a set of easy-outs.
 :o
