Author Topic: What's the problem????  (Read 1398 times)
Offline bert96
  • past ride
« on: November 01, 2007, 04:40:51 PM »
I try to start my bike today(cb750 k4) and i push the starter button for one second but the starter don't stop to crank even if i don't have my finger on the button!!!?
and the kill switch don't work ,so i had to turn the key off,
The only thing i did was to change my handlebar,i know it's an electrical problem but i don't know where to look...
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Re: What's the problem????
« Reply #1 on: November 01, 2007, 05:32:54 PM »
Starter button switch failure, my guess.
okie
« Reply #2 on: November 01, 2007, 05:40:38 PM »
Pinched wire in bars.
Offline bert96
  • past ride
« Reply #3 on: November 01, 2007, 05:46:50 PM »
  it's almost new,so i don't think so
When i finish the job(handlebar swap) everything was working,that why i'm lost :(
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: November 01, 2007, 06:43:08 PM »
I'm guessing the contacts of the starter switch won't separate either due to them "welding" together or a weak/broken return spring.  Do you know if brake fluid was ever spilled onto the switch?
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #5 on: November 01, 2007, 07:13:49 PM »
Are you sure your black and black/white wires inside the headlight shell are properly connected. Get a wiring diagram and ensure the starter button to starter are correct. Easy to get wrong...oh wait did you change your bars and switches or just the bars?
If only the bars then possible you pulled out one of the wires from the starter switch....open it up to find out....or starter switch is stuck!
good luck,
Andy
Offline bert96
  • past ride
« Reply #6 on: November 02, 2007, 05:08:54 AM »
[/quote
Nope,no oil in it.
good luck,
Andy
Thanks for your help guys,i will check that. ;)
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #7 on: November 02, 2007, 05:39:53 AM »
Hey all, yup my money is up in the handlebar the starter button wire is actually a ground so touch that wire to the handle bars and boom its gonna  turn the engine over. and  on a side note the kill switch even on kill will still let engine turn. open up that switch housing and bet you will find the gremlin  good luck.  have fun, Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
