Author Topic: What all can be done with the little CB550? (Turbo perhaps?)  (Read 27818 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: What all can be done with the little CB550? (Turbo perhaps?)
« Reply #75 on: January 03, 2008, 10:56:40 PM »
The main reason i was looking at using the VF parts is because my bike only has a single front disk...did the 550F get dual front disks? Because if so i would rather use factory parts instead to keep the spoke wheel look. Otherwise i wouldn't mind finding some comstars or some other mag wheels that will fit this bike.
no, but the fork legs were made so that a second disk could be easily fitted. the kit could apparently be bought at the parts counter back then. do a search for the mod on here and you'll find all the info you need. here's mine:
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #76 on: January 04, 2008, 01:53:26 PM »
Nice front end Paul, but I bet all that polishing keeps you busy ;D
My calipers are painted because I'm lazy ::)
Outlaw, if you're planning on following Paul's example (and you should it works), try swapping the forks side to side too, moving the calipers to the rear of the legs.
It doesn't make much difference to the actual braking efficiency, but the bike tends to dive a lot less under braking :)
1978 CB550 K3
1985 H100S
Offline DarkRider
« Reply #77 on: January 04, 2008, 05:44:55 PM »
Im def looking at going that route....Def like the idea of reversing the fork legs to mount the calipers behind them instead. Im assuming i would just swap the entire fork from one side to the other aka the right fork on the left side and vise versa?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline CrisPDuk
« Reply #78 on: January 04, 2008, 06:20:59 PM »
That's all I did, took about half an hour start to finish.
You have to keep the wheel the right way round though, so that the speedo drive stays on the right, otherwise it'll go backwards ;D
1978 CB550 K3
1985 H100S
Online MRieck
« Reply #79 on: January 04, 2008, 06:21:54 PM »
Paul..not nit picking but......that gap on the lower fork cap should face the rear. ;) Then again I don't have my glasses on so I might not be seeing things correctly.
« Last Edit: January 04, 2008, 06:24:01 PM by MRieck »
Offline DarkRider
« Reply #80 on: January 04, 2008, 07:59:00 PM »
Could leave it like that for about 4 thousand kms and i would have a zeroed out odometer lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline paulages
  • 1976 cb735
« Reply #81 on: January 04, 2008, 11:34:45 PM »
i'm not sure if i had it right on that picture or not, but i can assure you those caps have been off many times since i took that picture... i'm the king of nit picking  ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline snipcod
« Reply #82 on: October 01, 2008, 05:49:41 PM »
I was wondering about boring the 550 to fit the 750 pistons.  Every thing I've read here says it can be done but the cylinder walls get thin.  I would like to know to if these thin walls would lead to decreased engine life or would it not matter if done right.
It takes an idiot to do cool things, thats why it's cool
« Reply #83 on: October 01, 2008, 07:16:24 PM »
Yes the sleeve walls are thinner than stockers (at about 0.085") but it isn't a problem.
Offline snipcod
« Reply #84 on: October 03, 2008, 07:33:54 AM »
if thats the case I see no reason why I should not do this.  I mean other then the pain my wallet feels  ;)
