Author Topic: Gas cap gasket  (Read 1334 times)
Offline Patrick
Gas cap gasket
« on: November 06, 2007, 02:20:19 PM »
I need to install a new gas cap gasket on my K0 750 to keep the gas in the tank, rather than on the tank and, subsequently, my legs. The cap is actually from a K2 750. How does this come apart to get the new gasket on? The parts fiche calls the retainer a "screw," but it doesn't unscrew. It just turns and turns.
Suggestions anyone?
Patrick
« Last Edit: November 06, 2007, 02:29:50 PM by Patrick »
1970 CB750 K0
1982 VF750S Sabre
1987 VT1100 Shadow
1979 Yamaha XS11
1969 Yamaha DT1B
etc.
Offline Raul CB750K1
Re: Gas cap gasket
« Reply #1 on: November 06, 2007, 02:30:15 PM »
Get the new one before removing the old one. It justs fits in the cap lip. There are at least two tipes of caps: one with a retainer screw that you can remove, and one that is riveted and turns but you can't remove the inner cap and spring. Nevertheless -even when I have a new gasket waiting for replacement- I believe you can install it without removing anything, if you know what I mean.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Gas cap gasket
« Reply #2 on: November 06, 2007, 02:33:21 PM »
got a quick tip, I just did this on an old Farmall tractor.
Get a sheet of cork gasket material and cut out a circle for a gasket. Don't even need a whole sheet just a peice slightly biger than your cap. It's a quick cheap fix while you wait for the proper gasket.
 Matt.
Gallery at:
Offline jbailey
Re: Gas cap gasket
« Reply #3 on: November 06, 2007, 06:22:31 PM »
I got a new one a few years back for my 550.  Just a couple bucks and in stock at the dealer.  As I recall it just slips in.
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
Offline keiths
Re: Gas cap gasket
« Reply #4 on: November 06, 2007, 06:29:47 PM »
I replaced mine the year also. Cheap and in stock at the Honda dealer. They just stretch on as I recall. There was quite a bit of gunk under the old one.
Offline johnny
Re: Gas cap gasket
« Reply #5 on: November 06, 2007, 09:44:30 PM »
The recently installed gasket on my CB350F just stretched on. The (presumably) original one just crumbled in my hand.
1976 CB550K
1974 CB350F http://forums.sohc4.net/index.php?topic=81781.0
1974 CB550K
1972 CB350 Twin
1965 Lambretta
196(?) Honda S90
1975 Ford Bronco
Offline Hope
  • How did I become an
  • SOHC member since '01
Re: Gas cap gasket
« Reply #6 on: November 12, 2007, 09:04:36 AM »
Hopefully mine goes on this smooth.  I need a gasket for my 550K on my new tank I just had painted.
