Author Topic: K2: How does the fuel tap filter come out?  (Read 1317 times)
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« on: November 07, 2007, 02:28:30 AM »
How do I get this bit out then guys? I don't want to force it as it looks too fragile!
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Re: K2: How does the fuel tap filter come out?
« Reply #1 on: November 07, 2007, 02:35:59 AM »
That black rubber o-ring has to come out first.  Then the screen will be able to come out fairly easily.  It might have old gas gunk "gluing" it in, so you might want to use some carb cleaner on it to soften the old gas.
1977 CB750
« Reply #2 on: November 07, 2007, 08:13:41 AM »
Put a new "O" ring in as well Steve as they dont half get hard and misshapen
    • TVAM
« Reply #3 on: November 07, 2007, 12:43:30 PM »
Where do the new o-rings come from Bryan?
SOHC4 Member #2393
2015 Tiger 800 XRT
« Reply #4 on: November 09, 2007, 02:54:04 AM »
Now come on Steve you dont need to ask that one! D Silver Esq. 16958-268-010.
If you undo the two screws holding the tap to the tank fit new washers EITHER 6mm "dowty seal" washers (Alloy with rubber insert) from a Hydraulic shop OR the genuine Honda fibre ones 16993-011-000 which are an odd size and thick so you cant get generick ones and damned expensive for what they are
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #5 on: November 09, 2007, 05:17:12 AM »
Hey there Steve, sounds like a rebuild kit is in order. ebay has them a bit pricy but well worth it you get all pieces needed even new screws. Now I have gotton the right orings needed b 4 at my local hardware store. but id you need all pieces ebay is the way to go. good luck Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
