i went the double disc set up, with stainless lines, VTR1000 master cyl, and mine still feels a bit spongy, but if you got the lever anywhere near the bars the front would be locked..... and as two tied said, get rid of the nylon spacer, that will remove the compression, also check tht you havent got too much free play in you brake pivot arm...
hope this helps
peace
