Ok, so presuming the 1080 kit might be a bad idea for street use, what about this thought? I've got a forged 836 kit (ART pistons) that I believe is around 10.5:1. Double base gaskets would reduce that to just a bit about stock compression, around 9.5:1. I think double base-gaskets is the best I can do without requiring a longer cam-chain. That setup could take atleast 5 pounds of boost without the need for anything too drastic. Assuming I get a real good set of rods (falicon or carillo), micro-polish and chamfer the crank, and rebuild the engine from the ground-up with back-cut gears and new chains and everything, that should make a real nice street-turbo SOHC. Meth injection just for added protection, along with an oil-cooler. Run a Dyna2000 with the adjustable advance curve, etc. I might even be able to pull 20 mpg out of that setup with proper tuning and easy riding.
As another thought, could I mill 10 or 20 thou off of the ART pistons without compromising them? That would get me all the way back down to stock compression (give or take). I've decided I really would like more of a street bike than a drag bike that occasionally gets ridden on the street...
