Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
If you bead blast it, you won't want to paint it because it will look so good. I bead blasted a 350F tank a couple of months ago and was really pleased with the results. If there is a downside, I haven't found it. I would suggest using a power sander first to get the striping off, otherwise the striping acts as a mask to prevent the beads from working.
