Author Topic: Missing Honda Twins!  (Read 1586 times)
Offline Killer Canary
  • Typical Bran Muffin
« on: November 12, 2007, 06:27:26 PM »
In the meantime, I'm rebuilding the forks on my '72 CB 350 twin and I'd like to retire the steel tube covers. Has any one substituted standard dust seals, or even fork gaiters? Tube diameter is 33mm,inner slider diameter is 47.5mm, outer slider diameter is 54.5 mm. Does anyone know of another bike that uses this size of dust seal?
Kawi GPz900, H1
Offline ohiocaferacer
  • www.OHIOCAFERACERS.com
    • OHIO CAFE RACERS
Re: Missing Honda Twins!
« Reply #1 on: November 13, 2007, 03:53:45 AM »
CB360 dust covers will work with the 72 CB350 forks.
Later,
Greg
« Reply #2 on: November 13, 2007, 09:57:34 AM »
Thanks Greg!
Kawi GPz900, H1
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #3 on: November 15, 2007, 11:22:44 AM »
forum fixed.
Sorry.
No.
Offline 333
  • Time for change
« Reply #4 on: November 15, 2007, 11:30:30 AM »
The problem is that , like the F, the forks are not chromed all the way up.  The upper pieces which also hold the headlight cover where the chrome stops.  You might get away with just removing the lower section, but if you were thinking of removing both and using an alternative headlight mount, you'll have to get fork tubes that are chromed all the way up.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #5 on: November 15, 2007, 02:59:08 PM »
I have a set for 33mm forks ifin you in need.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline DarkRider
« Reply #6 on: November 27, 2007, 02:05:02 AM »
You could also adapt Offfoad truck shock boots in place of the gaiters. This is a trick that i found on either this forum or another bike forum.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
« Reply #7 on: November 28, 2007, 11:02:12 AM »
I used universal fork gaiters from Emgo. Look good!
Kawi GPz900, H1
