Author Topic: Using pre-77 cab insluators on post-77 carbs  (Read 1261 times)
Offline mrosso
  • The before picture.
« on: November 14, 2007, 05:32:31 PM »
I have a set of new carb insulator rubbers I bought a while back for my '71 CB750. I just bought a set of '78 carbs off of ebay. Can I use the '71 insulators with the '78 carbs?
fuzzybutt
Re: Using pre-77 cab insluators on post-77 carbs
« Reply #1 on: November 14, 2007, 05:43:18 PM »
no, the 77/78' carbs have a larger diameter.
sohc4
« Reply #2 on: November 15, 2007, 03:23:12 AM »
On the engine side, all the carbs have the same diameter, but the '77/'78carbs have a larger dia on the airbox side.
But - the earlier insulators are longer than the '77/'78s, they will give you a headache if you are using the airbox.  No problem if you have pods or stacks, though.
Offline scondon
  • Mmmm......tasty bugs
« Reply #3 on: November 15, 2007, 08:46:52 AM »
78 carbs are bigger on both ends, just measured to confirm. Am guessing it's the same for 77 carbs(CB750).
'76 carbs outlet-  37mm
'78 carbs outlet-  41mm
Axl, that you?  :)
sohc4
« Reply #4 on: November 15, 2007, 12:50:53 PM »
Yep, it's me.  Hmmmm - I didn't measure them up but I know I had mounted '77 (K7) carbs using the earlier insulators  ???
Offline scondon
« Reply #5 on: November 15, 2007, 01:33:20 PM »
 The only "pumper" carbs I have are from the "F" models, though I thought from discussions here that the "K" carbs had same dimension. I am certainly prepared to be wrong on this as I hate spreading mis-information ;)
   Either that, or years of putting bikes together have given ya "Popeye" strength ;) ;D
« Last Edit: November 15, 2007, 01:36:15 PM by scondon »
Offline eurban
« Reply #6 on: November 15, 2007, 01:50:17 PM »
Don't know how they compare to the earlier carbs but the F2/F3 and K7/K8 carbs are identical as far as the size of the fittings on the airbox and the engine side of the carbs.  F2/F3 have larger diameter spiggots that screw into the head.
Offline scondon
« Reply #7 on: November 15, 2007, 02:22:01 PM »
  That's how I remember it. Thanks,eurban :)  Haven't forgotten about taking piston pics, just need some time in the garage to clean and compare them. Will post when done.
sohc4
« Reply #8 on: November 17, 2007, 12:29:01 PM »
I stand corrected - sorry  :o  Now, the question remains, how did I get these '77 carbs onto the earlier insulators?  Must have had that extra helping of spinach before  :D
« Reply #9 on: November 17, 2007, 01:14:12 PM »
To install 77/78 K or F carbs onto a K or an early F (F/F1) head, you need K7/K8 insulators. been there, (last summer) done that.
Another problem that you may encounter with the conversion is that the F2/F3 airbox (and presumably the K7/K8 item) which you'll need as the K0-K6/F/F1 airbox won't fit the later carbs, is slightly larger in width than the earlier item, and you'll crack your left sidecover trying to install it. I did...........  :'(
« Last Edit: November 17, 2007, 01:18:41 PM by Terry in Australia »
