Author Topic: Broken Cam Chain Sprocket and Camshaft???  (Read 3017 times)
DGoody
« on: July 23, 2005, 02:40:47 PM »
Hey all.....I'm a newbie, please bear with me. I did a top end rebuild on my wife's 1975 CB400F this week. I started it up and it idled for about 10 minutes, then it just stopped dead. Thinking that the cam chain sounded loud, I pulled the heads back off and noticed that the cam chain sprocket and camshaft mounting flange had broken completely off. The sprocket bolts had come out, but didn't break, and were sitting right near one of the valves. But, at one of the sprocket mounting points, both the sprocket and camshaft flange (where the bolt threads) had broken. I think I got all the pieces out of the tunnel, and it looks like I need a new sprocket and camshaft. When I manually turn the crankshaft, it seems to move a little less free than before, but still rotates okay.
Anybody have any ideas why the hell this happened? My wife is going to kill me now!
DGoody
Re: Broken Cam Chain Sprocket and Camshaft???
« Reply #1 on: July 23, 2005, 07:57:23 PM »
Well as it turns out, I think the culprit was the rear slipper arm. I had installed it backwards.....in other words, the guide side was facing the rear, and the chain must have been hitting the back of the slipper arm, putting undue tension somewhere and causing the breakage.
I guess I just rushed through the reassembly.........makes sense that this would cau
« Reply #2 on: July 24, 2005, 12:42:28 AM »
Well I guess your wife killed you halfway through that last sentence mate, or maybe you've faked your own death and are reading this in an internet cafe in Argentina?
Anyway, I'm leaning toward supey's suggestion that you've done some damage in the top end, so you might want to whip the head off for a closer inspection before you just sling in another cam mate, I'd be very surprised if you haven't? Cheers, Terry. ;D
Offline Harry
    • CB500F
« Reply #3 on: July 24, 2005, 01:47:37 AM »
Mrs DGoody after the sudden death of your husband, I suppose this is not a good time to talk about your petrol tank  ;)
;D
Harry Teicher, member #3,  Denmark....no, NOT the capital of Sweden.
« Reply #4 on: July 25, 2005, 08:56:20 PM »
Typical Scouser! LOL ;D
« Reply #5 on: July 26, 2005, 12:27:52 PM »
Dave , can you not wait till after the funeral?
Ben
« Reply #6 on: July 26, 2005, 04:20:53 PM »
Sounds like you may have put the cam sprocket bolts in the wrong holes? I think one is 'stepped' and the other a straight thread. If you put the stepped one into the straight thread hole it will split the mounting flange............ Just an idea.
« Reply #7 on: July 26, 2005, 05:19:08 PM »
Hey Dave, when are we going to get together for a drink?
