Author Topic: 73 CB 750 Cafe Racer Project OCR / BCR Style  (Read 128395 times)
Re: 73 CB 750 Cafe Racer Project OCR / BCR Style
« Reply #100 on: June 04, 2008, 04:19:35 AM »
Looking good! That tail section is amazing!  8)
Offline bunghole
« Reply #101 on: June 04, 2008, 10:06:12 AM »
Dear God Man!
That is some fine work!
Why do I have to work?  Why can't I just live in my garage and tinker on my bikes?  Isn't there some foundation that will grant me a fellowship to rebuild motorcycles?  I'm sitting here reading this thread and I'm just aching to get the hell out of the office so I can build something even one/tenth as cool as this.
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline dagersh
    • Photos
« Reply #102 on: June 04, 2008, 12:18:23 PM »
Dear God Man!
Amen to that!
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline bgfootball67
« Reply #103 on: June 04, 2008, 03:50:02 PM »
Void909, that rotor was drilled in the exchange program up at Cycle Exchange, Ken does nice work!
Thanks for the kind words Andy, I am pretty pumped to see the whole damn thing together.  Having a hard time waiting....
I hear you about that, I work way too much and do not have enough times for my hobbies (this project started 10/06).  I doubt this would be as much fun if you did it full time though.
Columbus VinMoto
Ohio Cafe Racers website - http://www.ohiocaferacers.com
« Reply #104 on: June 04, 2008, 06:44:50 PM »
my brother is an ASE cert. (car) mechanic, and once told me:
  "you will ruin a perfectly good hobby by doing it for a living"
Offline void909
« Reply #105 on: June 05, 2008, 01:46:24 AM »
Do you have a number i can call or an email address for them? I really need to get my set drilled.
knock with no answer
« Reply #106 on: June 05, 2008, 03:54:31 AM »
http://www.cyclexchange.net/
Good people, good stuff....
Columbus VinMoto
Offline chrislib
« Reply #107 on: June 05, 2008, 04:01:48 AM »
Very true (as I get ready for another day of "fun").
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
« Reply #108 on: June 17, 2008, 08:38:47 PM »
Been working on the exhaust a bit over the last couple weeks.  I ended cutting off 2" of the pipe where it mounts into the engine, had the ends flaired to use original mounting spickets.  Cut an 1 1/2" out of the head piped so the collector tucks back up under the frame.  Big thanks goes out to Jesse and Greg...
Before
During
After
Columbus VinMoto
Offline hopterfixer
    • My flickr Gallery->
« Reply #109 on: June 17, 2008, 09:02:18 PM »
I can't wait to hear it.
Offline bunghole
« Reply #110 on: June 17, 2008, 09:19:16 PM »
bgfootball,
Sorry if you've already discussed it, but what type of paint did you use for the cylinders?  Is it gloss or flat?  Do you like how it came out?
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
Offline KB02
« Reply #111 on: June 18, 2008, 04:54:38 AM »
That pipe looks WAY better now. Well done. too bad you had to pay how much and then fix it, too?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #112 on: June 18, 2008, 06:36:00 AM »
Hopeterfixer, I can not wait to hear it either!!!  Trying to make a push to get her together and running!
Bunghole, the paint on the head is a satin black, not true gloss or flat.  Can not remember the brand off the top of my head.  Need to go back and touch some areas up once I am getting ready to roll.
KBO2, I changed the way they mount to the head because I am picky and like the stock look better.  I wish they would have tucked up under the frame better too, but it was fun cutting them up, welding them and grinding them.
Now off to sanding them down and hitting them with some 2000 degree paint and then the thermatech header tape I picked up at Jegs.  That stuff cost more than I thought.....
Columbus VinMoto
« Reply #113 on: June 22, 2008, 03:35:08 PM »
Here is this weekends progress, was able to get pipes painted, wrapped and installed.  Put chain on bike, tach and speedo cable.  I ended up puting the body work on so I could get a feeling where I want the handle bars.  Enjoy the pics.  I need to get this damn thing running now, spent most of the afternoon just stairing at her.....
Pipe work
Pipe Painting
Finished wrapping
BCR Bodywork Anyone?
My vintage license plate
Waiting on custom clutch and throttle cables, front brake pads, CRG lane splitter mirror, trying to get a cool fork brace from spec 2 and wiring then done.  Anyone here have any good suggestions for a cool fork brace that will work on my 73 CB 750?
Columbus VinMoto
« Reply #114 on: June 22, 2008, 07:18:59 PM »
"Anyone here have any good suggestions for a cool fork brace that will work on my 73 CB 750?"
When the tire is higher than the top of the fork leg, we seem to be limited to the fork brace which was actually part of the original fender. One interesting twist on that I read in a post on the forum, was to use two such braces. Slott the holes in one so it can be mounted over top of the original. Sandwich a fender in between.
A "tweek" bar mounted just below the lower triple clamp will help take out some tube flex as well. In the old days, some guys would take a lower triple clamp, press out the stem, and weld it to the existing triple clamp giving a double clamp effect to the tubes. On our old skinney tube bikes, firming up the tube flex was as important as holding the lower legs together.
Offline dagersh
    • Photos
« Reply #115 on: June 23, 2008, 02:46:34 PM »
Bigfootball -
THAT'S AWESOME!!!!!!!!
Exhaust looks great, and the bodywork looks perfect mounted up!
Get her running, we need video with sound!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB500K1
1975 CB550F
1976 CB400F
1976 CB750K6
1976 CB750F
1976 GL1000
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Ricky_Racer
« Reply #116 on: June 23, 2008, 08:38:54 PM »
Gorgeous build!  Any close-up pics of the super-sanitary battery box setup?  It's great that you didn't cut the frame brace.  Thanks!  RR
« Reply #117 on: June 23, 2008, 08:51:01 PM »
I can't see the pics from my DOD computer, I'm just "marking the spot" so I can find it again when I get home. ;D
Offline hopterfixer
« Reply #118 on: June 23, 2008, 09:34:14 PM »
There goes Terry "marking his territory" again......
« Reply #119 on: June 24, 2008, 12:20:09 AM »
Ha ha, well that bike looks great mate, you've done well! I love your blue Suzy with the early GSXR wheels and front end, I did that with one of mine years ago, I wish I'd kept it! (now if you need to get those left over GS1000 parts from your chopper build out of your garage, you can always send them to me............)  ;D
Offline greenjeans
  • 1972 CB750K2
« Reply #120 on: June 25, 2008, 02:44:18 PM »
Good Lord!  How did I miss this build.
kick-ass.
« Reply #121 on: June 25, 2008, 03:15:52 PM »
bg that is museum quality good, you should be very proud (witch i'm sure you are)
i gotta tell ya, i wasn't very fond of the rising sun (i understand the significance, just didn't care for it)   but seeing it on the bike, getting the "big picture" .   man i'm sold, ... i want one
i love it , you covered all the bases:
   1. it looks mean
   2. it looks super clean
   3. you've got tons of original work, done buy you (for the most part)
   4. it just LOOKS fast
   5. i'm betting it sounds mean as hell (the kind of exhaust that scares old people and little kids as you ride by)
   6. and finally , a totally original, totally sick paint job
well done my friend ,well done
enjoy your BOTM honors (you know your gonna get them)
martino1972
« Reply #122 on: June 28, 2008, 02:27:30 PM »
very,very nice......thumbs up for the build,and yeah,would love to see a video of that thing in action...
amazing build,perfection all over....
but now we have seen you and your adorable son(wrong for a guy to say"adorable"????)...
but where's your wife???? ;D ;D ;D :D :D :D ;D ;D ;D...............
masonryman
« Reply #123 on: June 28, 2008, 03:58:36 PM »
I have been amiss for awhile, HA HA, any way just skimmed through the build and it is looking very nice.
I seen your from eastern Ohio, I'll be at C.A.P.T. and Honda of America the week of July 4th.
Mark
« Reply #124 on: June 29, 2008, 05:39:10 AM »
Hi Everyone thank you for the kind words about my build.  I am pretty stoked to finally put the finishing touches on her the next couple of weeks.  The guys that rebuilt my engine are fabing a custom wiring harness as we speak an then are going to do the final tune on the engine/carbs...
Terry, I will let you know about the GS chopper build, I am going to try and reuse as many as the original pieces as possible...
Spikey, I would be very honored if this bike won BOTM awards from this group, especially with all the killer bikes that have won in before.  I am digging how the bike is turning out, if I had to do all over I would change a few things but for the most part I am happy..  The biggest thing is I wish I had more time...
No good pics of the old lady on the bike, she has not really road for the last two years.  Once she found out she was pregnant she put up the keys to her Harley.  In the last two years my little brother and I are the only ones to fire her up for any good rides.  I did recently get her out on her bike for a B-day ride!
I did find a brace out of Germany, Telefix.  It is going to take a few weeks to get here and cost an arm and a leg, but I will let you guys know how it turns out.  They have 3 American dealers, Spec II and Bob's BMW had piss poor service.  Irfan at Wild Hair Customs hooked me up the same day, good stuff.....
My plan is to wrap everything up and have her finished by Vintage Days so I can enter her in the cafe show on Saturday.  I doubt I am going to be able to be there the entire weekend, but am looking forward to hanging out a bit.  Getting ready to switch jobs so not quite sure what is going to be expected in the new position.....
Masonaryman, not heard of the event you are speaking of.  Are you talking about the rally they have at the factory?  I actually no longer live in Dayton, moved to Columbus almost two years.  I still work in Dayton until the July 11th, but then to Columbus.  Can not wait to start saving on gas and get back 2 hours and 20 minutes of my time every day!
Columbus VinMoto
