If this bike has been sitting for a long time, I would just get new points and condensers.
I'm with oldbiker on this one--if it ain't broke, don't fix it. Smooth the points with emery or one of those cool points files still available at Checker Auto. Then clean them well, using plain white paper as the last step. Might not be perfect, but it should get you running. Then you can decide if new points are needed.
Don't think I've had to replace a condenser in several decades of tinking with old bikes.
Easy way to eliminate fuel problem question is to spritz some ether
through each carb. If there is ANY spark, it'll fire.
