Author Topic: Tank dented where petcock mounts  (Read 710 times)
Offline fmctm1sw
« on: December 01, 2007, 07:48:04 PM »
How would you attack this?  I have tank that has been dented somehow (dropped with the petcock on it maybe) along the bottom where the petcock mounts.  I tried using body filler along the bottom to level it out with disappointing results (it leaked).  All I have to do is get a good flat surface where the rubber gasket is on the petcock right?  Is this a losing battle?
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Re: Tank dented where petcock mounts
« Reply #1 on: December 01, 2007, 08:52:25 PM »
I would drill a piece of flatbar with same hole pattern as petcock (I assume this is the 75  or 76 and down one)
Then weld a bar in the middle like 1/2 in or wahatever fits.. about a foot long.. now bolt it on and bend it back.
If the petcock is still there check for cracks...
