I re-read the faq section which says this:
"I need to sync my carbs but have no vaccum meter. How do I bench-sync?
When I rebuild a set of carbs, I always bench sync them before I re-intall them. Basically, I use a 1/8" drill bit as a gage. Here's how you do it: Adjust the idle screw (the main one) until the 1 carb outside of it is open enough to just let the 1/8" drill bit through. Then adjust the _sync_ screws on the other 3 carbs until the drill bit just fits them as well. You'll probably want to close the idle screw before you bolt them back on the bike, 1/8" openeing is pretty big. This isn't a perfect sync, as there are other things that will affect the airflow to a given cylinder, but it will get you pretty close."
It looks like I missed the part where you adjust the idle screw first. I will go back and set the carbs up this way and start from there. I do remember however first starting the bike and having to turn the idle screw to get the bike to stay running. So I will check it out and post the results when Im finished.
-thanks so much everyone for the help!
