Author Topic: X-Ring Chain on '71 CB500/4  (Read 1267 times)
Offline chopstar500
  • King of the Nighttime World
« on: December 11, 2007, 07:20:28 PM »
I've heard of the problems using a X or O Ring Chain on the 550 - does this also apply to the 500?
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline mark
Re: X-Ring Chain on '71 CB500/4
« Reply #1 on: December 11, 2007, 08:20:28 PM »
Somebody just recently posted pix of the case wear on a 550. My guess, based on the arrangement of the clutch parts, is that the 500 would suffer worse.
F you mark...... F you.
Offline hymodyne
« Reply #2 on: December 11, 2007, 09:00:39 PM »
I believe its too wide for the 500K
hym
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #3 on: December 11, 2007, 09:12:40 PM »
You can do it if you turn the centre of the front sprocket and back space it away from the cases.
The O-ring chain that I used meassures 0.200" wider than the non O-ring chain that was on the bike.
I had the front sprocket narrowed in the center by 0.100" and then put a 0.100" spacer behind it.
Problem solved.
