Author Topic: 1975 cb750 4. K5. CArb boots  (Read 1113 times)
Offline Halltm
« on: April 22, 2020, 05:41:02 PM »
Any suggestions on where to get new carb boots(manifolds) ?
Thanks
Re: 1975 cb750 4. K5. CArb boots
« Reply #1 on: April 23, 2020, 12:06:26 AM »
If you mean carb to head go to Honda
« Reply #2 on: April 23, 2020, 01:09:18 AM »
Avoid cheap aftermarket, they crack asap so they are expensive.
DSS, Cmsnl and where they sell Honda original parts.
Offline Doobie
« Reply #3 on: April 23, 2020, 04:29:56 AM »
Cheapest OEM is likely jtmarks@hvc.rr.com (sells on eBay and is member here). Send him an email with parts numbers and he'll send you a PayPal invoice. Very fair shipping too.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline Johnie
« Reply #4 on: April 23, 2020, 08:22:29 AM »
I get mine from my Honda dealer...this OEM stuff won't let you down like that aftermarket stuff.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Halltm
« Reply #5 on: April 24, 2020, 04:42:26 AM »
Thanks.    Getting close to firing it up for the first time since 91.
« Reply #6 on: April 24, 2020, 05:29:25 AM »
  If the old ones are not cracked but hard and stiff a heat gun will soften them up long enough to work with them. New is good also if the quality is there.  Old hard and deformed air box boots are a pain in the arse also !
