SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
I can't get my head off.........
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: I can't get my head off......... (Read 2880 times)
clarkjh
Expert? If only.
Expert
Surely and Samson are now Co-habitating
on:
July 26, 2005, 01:48:55 PM »
I can't seem to get the head of my 74 CB550 to come off. It's loose
, rocks back and forth a little bit but will not slide up
. The gasket cement that some PO used is holding the head on good but leaked like a cive. Any advice on how to get this thing apart without trashing the head. I have been trying for two nights to get this thing off and have had to give up before I lost my cool and used the BIG hammer, (18 lbs)
thanks
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
eldar
Guest
Re: I can't get my head off.........
Reply #1 on:
July 26, 2005, 02:00:39 PM »
Well you could get a flat spreader about 1 - 2 inches wide. It is soft metal so it should not damage anything. Put it in between where the gasket is and tap with a SMALL hammer, no big hammer for this! It should break up the cement. You will have to clean the cement out but if you are pulling things apart, you know this.
Logged
clarkjh
Expert? If only.
Expert
Reply #2 on:
July 26, 2005, 02:03:21 PM »
eldar
Thanks for the info, I'll give it a try after the news. If it works you will have saved my sanity and my little 550.
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
eldar
Guest
Reply #3 on:
July 26, 2005, 02:14:40 PM »
That stuff can be a pain when it is old. Screwdrivers will damage the seats for the gasket but if you are careful, this should be ok.
Logged
clarkjh
Expert? If only.
Expert
Reply #4 on:
July 27, 2005, 05:52:04 AM »
I keep repeating "I will Not use the BIG hamer". Man this head is STUCK good,
thinking maybe gasket cleaner might help soften things up.
Logged
SOHC/4 #3328
SOHC/4 Gallery:
Bob Wessner
"Carbs Suck!"
Really Old Timer ...
Reply #5 on:
July 27, 2005, 06:09:14 AM »
Must be the change in weather today, but how's this for another hairbrained idea. If you are sure all fasteners are out and all that is holding it on is the gasket an/or any sealer used, what if you chilled the head with some bags of ice for a while to eliminate adhesion, then gently gave it some taps around with a block of wood and hammer?
OK, I'm prepared for any ridicule.
Logged
clarkjh
Expert? If only.
Expert
Reply #6 on:
July 27, 2005, 06:21:19 AM »
Bob
At this point I'm willing to call in the local witch doctor if it would help. My kit should be in today or tomorrow and I'd like to be able to ride this weekend.
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
bryanj
CB500 Number 1000036
Reply #7 on:
July 27, 2005, 07:06:16 AM »
Are you sure you got the two small bolts one in front one in back. Also the bolts out of the cam chain tensioner? Its the cylinder that is usually the awkward one as crap blocks up the holes at the bottom and the threaded part at the top of the stud dont want to go through.
Logged
oldbiker
Expert
I HATE RAIN
Reply #8 on:
July 27, 2005, 07:38:10 AM »
I had this problem when I removed the head of my cb400f. Turned out it was crud or corrosion in one of the tunnels that the head studs pass through. Squirt some WD40 (penetrating oil) into the tunnels to soften the crud.
Logged
cben750f0
nothin draws attention like a classic bike!!
Master
'75 CB750F0 Gladstone NQLD OZ
Reply #9 on:
July 27, 2005, 07:59:37 AM »
you havent got some rusted in dowels??... just a thought, i had trouble getting the head off the 750... and it was because the dowels had rusted in.... i just kept wobbling it till it came free.... just a though....peace
Logged
he said \\\\\\\'it was like watching a 250kg unguided weapon getting stuck up you bum\\\\\\\
http://www.bikepics.com/members/trixtrem/
clarkjh
Expert? If only.
Expert
Reply #10 on:
July 27, 2005, 08:19:19 AM »
I'm starting to think it's a combo of crud and the cement that was used. I can wiggle the back and forth, but I can't get any up/down movement. I also have be spraying liberal amounts of penetration oil to no avail.
bryanj
all bolts are removed, including the one on the front and back.
Still with the engine in the state its in right now, it just wants to make me cry
I also knew that this would be a project in motion.
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
mnb70405
Guest
Reply #11 on:
July 27, 2005, 10:16:39 AM »
i can recal on the fours as it has been a few years since i sold of my cn750, but on the twins the timing chains runs to the top of the motor around the cams and around the bottom main shaft. Did you "break" the timing chain?
Logged
clarkjh
Expert? If only.
Expert
Reply #12 on:
July 27, 2005, 10:38:33 AM »
On the 550, you remove the timing cog then the chain slide off and you pull the cam out. Just don't drop the $@!#^% chain down in the case, no I didn't, but I have on a GS400 DOHC engine, its a pain in the ass to get back out.
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
clarkjh
Expert? If only.
Expert
Reply #13 on:
July 27, 2005, 01:36:10 PM »
Bob, Sherrie
I'm a Moron.
Thanks to all who replied with advice. I got my head off finaly.
The problem seem to be I can't count. While taking out the washers with a grapper tool I found a nut I was sure I had removed. Man is the head carboned up bad.
Thanks again for all the help
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
Bob Wessner
"Carbs Suck!"
Reply #14 on:
July 27, 2005, 02:14:38 PM »
Glad to hear you got it off. Now on to the rest of the work, eh?
Logged
clarkjh
Expert? If only.
Expert
Reply #15 on:
July 27, 2005, 02:30:14 PM »
Bob
You said it, it's gona take a month of Sundays to get the crap off head, valves and pistons.
James
Logged
SOHC/4 #3328
SOHC/4 Gallery:
cben750f0
Master
Reply #16 on:
July 27, 2005, 02:44:17 PM »
WOO HOO good to hear old son!!!... peace
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
