Author Topic: Picture of a totally rust free tank  (Read 4240 times)
Offline GNXFan
« on: December 27, 2007, 05:21:45 PM »
I just wanted to post a few pics of a tank I have been soaking in a rust remover called Evaporust. There are other posts regarding this product but I wanted to show how good it works. My son gave me a 5 gallon bucket of it for Christmas so I completely submerged it in the stuff. I've also posted a pic of an oil tank I soaked. I use it all the time and love it. Now...where's my check for the product plug.
« Last Edit: December 27, 2007, 05:27:47 PM by GNXFan »
Offline heffay
Re: Picture of a totally rust free tank
« Reply #1 on: December 27, 2007, 05:25:38 PM »
you missed a spot
Offline fastbroshi
  • Puppet
« Reply #2 on: December 31, 2007, 11:12:58 AM »
Noice ;D
Just call me Timmaaaaay!!!
johnrtse
« Reply #3 on: December 31, 2007, 05:51:06 PM »
Nice!
Do you have to remove the paint or do any de-greasing before you dunk the parts?
John
Offline GNXFan
« Reply #4 on: December 31, 2007, 06:55:33 PM »
Well on this tank I did strip the paint off with a citrus paint stripper first but even after that the bottom of the tank still had surface rust and the inside was rusted also.
Offline azuredesign
  • Knupping pin
« Reply #5 on: January 01, 2008, 04:24:25 AM »
What did the stuff do to the two grommets I see on the oil tank?
Looks great btw! Do you have to create a phospate layer inside the tank to keep it from re-rusting?
All best,
Ben
Offline GNXFan
« Reply #6 on: January 01, 2008, 07:11:54 AM »
The rust remover did not affect the rubber grommets. The grommets are the original ones, in good shape but getting hard. I plan on removing them before I powdercoat the oil tank. After I get the rust off I just let the rust remover dry leave a film on the tank. In other words just remove the part from the remover and let it dry with no water rinsing.The tank has been stored in a box in my garage since the 27th and has no flash rust at all so far.
Offline sandcastcb750
« Reply #7 on: January 03, 2008, 02:08:39 PM »
Is this stuff caustic; opposite of acid? Usually caustic only eats the oxide not the steel. But eats aluminum.
Offline GNXFan
« Reply #8 on: January 03, 2008, 05:11:02 PM »
The label says it is safe for copper, brass, aluminum,galvanization,plastic, rubber or vinyl. It contains no acids or alkalis and is non-corrosive.
Offline mrblasty
  • Expertly
« Reply #9 on: January 03, 2008, 06:17:58 PM »
Looks shwheat, I'll need to try the stuff.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
