Pat,
my whole thought has been - I've stuffed it up big time...but knowing how tough these buggers are I'm hoping there is no lasting damage............
Tolerances for the oil pump as follows:
Delivery Side outer rotor to body clearance - between .09 to .10mm, inner to outer rotor - about .15mm
Scavenge side outer rotor to body clearance - between .15 to less than .20mm, outer to inner rotor about .13mm
thankfully well within tolerance levels....
I now need to order the following bits to put back together
1 - oil filter screen (stuffed that up big time)
2 - oil filter & new oil filter bolt
3 - oil
4 - lots of bungs from Honda (hope they have them)
5 - transmission cover gasket
6 - clutch cover gasket
7 - 4 hours of good labour to put the bugger back together....
I also need to beg,borrow,bludge, or buy from a few local guys - another spiral cut clutch plate...clean up all my old ones -check for warpage - clean the whole clutch basket and assemble...the list goes on forever.....
