Author Topic: Figured out solo seat mounting on factory frame!  (Read 3179 times)
Offline cbass*gxc
    • My Pics Page
« on: January 10, 2008, 01:29:45 PM »
Ok here is a pic of how it will sit with the white line being the bracket.
Here is a 3d rendering that I made of the bracket.  Anyone wanna make this for me?  Also could this be made by bending some slightly thinner metal instead of welding 3 different pieces?  The top part is 6" long and it sits 2" high.  (After I look at the pic I am thinking maybe it should be inch and a half high) The bottom of the bracket is an inch and a half.  I do not know what thickness would be the best for this but was thinking no more than 1/4"
Here is a link to the pdf of the drawings and dimensions.
http://jaypage.com/pics/motorcycle/Seat%20Bracket%20-1.pdf
Offline Joel
Re: Figured out solo seat mounting on factory frame!
« Reply #1 on: January 10, 2008, 01:48:44 PM »
Is it going to flex when the seat is occupied?  Should the bracket also rest on the frame in front of the seat?
Offline cbass*gxc
    • My Pics Page
« Reply #2 on: January 10, 2008, 01:51:37 PM »
Ya i was thinking about the but I figured with the 2 springs in the back as well I figured it would be alright.  But I do not know.  Was hoping to get some input on it.
Offline Joel
« Reply #3 on: January 10, 2008, 01:55:01 PM »
So there will be fasteners holding the back down?
Offline cbass*gxc
    • My Pics Page
« Reply #4 on: January 10, 2008, 01:56:10 PM »
Ya I am still going to be using the seat springs on the rear 2 bolts.   These are the springs I am going to use..
http://cgi.ebay.com/ebaymotors/2-CHROME-SEAT-SPRINGS-HARLEY-BOBBER-CHOPPER-13-0273_W0QQitemZ370011398980QQcmdZViewItem?hash=item370011398980
« Last Edit: January 10, 2008, 02:00:15 PM by cbass*gxc »
Offline Joel
« Reply #5 on: January 10, 2008, 01:59:33 PM »
Do you have a photo of the rear mounting and springs?
I'm thinking that if the rear springs are functional, sitting in the seat will cause the front to droop on that bracket and the rear to lift and stretch the springs.
Offline cbass*gxc
    • My Pics Page
« Reply #6 on: January 10, 2008, 02:03:56 PM »
I thought about that but I figured with it being 1/4" thick it shouldnt flex too much, but I guess there will be quite a load on the front of that.  I guess I could go smaller metal and take it all the way to the front, then maybe I could make it myself.
I guess really I could turn that bracket around and it would be alright?  Just mount that bottom piece up by the tank and that would work too.
« Last Edit: January 10, 2008, 02:05:48 PM by cbass*gxc »
Offline Joel
« Reply #7 on: January 10, 2008, 02:05:04 PM »
I'd suggest that.  It'll also be lighter that way.  Will it be visible when the bike is finished?
Offline cbass*gxc
    • My Pics Page
« Reply #8 on: January 10, 2008, 02:07:04 PM »
Ya that was the reason I was trying not to have it come out the front.  Bet I could put a couple sets of holes and try it both ways.  I am running by lowes when i get off to see what they may have.
Offline cbass*gxc
    • My Pics Page
« Reply #9 on: January 10, 2008, 02:10:41 PM »
Ya I have some foam core from work that I am going to take home and mess with alittle this evening and see if I can figure something out.
Offline Joel
« Reply #10 on: January 10, 2008, 02:14:40 PM »
Are there any existing holes in front of the seat that could be used to mount a bracket?
Since it's going to be visible, you could try making an arch.  That shape might blend better.
Offline cbass*gxc
    • My Pics Page
« Reply #11 on: January 10, 2008, 02:17:06 PM »
Thats a good idea.  I will mess with it the evening and see what I can come up with.  i will post pics of my findings.
Offline flankspeed
« Reply #12 on: January 10, 2008, 02:45:55 PM »
May also want to look at the seat hinges fab kevin makes for solo seats...might be close to what you're looking for with a bit of tweaking.
Bolt on version
http://www.fabkevin.com/seat%20hinge2.htm
Weld on version
http://www.fabkevin.com/seat%20hinge.htm
Good luck!
1973 cb750
1971 Triumph 650 rigid
Offline cbass*gxc
    • My Pics Page
« Reply #13 on: January 11, 2008, 07:41:39 AM »
Flank those are some really nice brackets.  May have to purchase one of those on the next bike I build.  They look a little too nice for this one.
Well went to lowes and bought a piece of about inch and 1/4 wide by 1/8" thick hot rolled steel and made myself a bracket last night with the torch and hammer.  Her is a pic of what it looks like.  I am going to do alittle more work to it with the grinder to make it look a little better but for 30 minutes worth of work I am not complaining.  The 3" seat springs are too big so I am going to order some 2" springs this week.
Offline Joel
« Reply #14 on: January 11, 2008, 11:15:08 AM »
Looks pretty good.
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #15 on: January 11, 2008, 05:30:44 PM »
I love that curved strut action you got going on there! The seat looks pretty good too but imagine how good it would look with that $120 stainless front bracket hiding under it ;)
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Offline cbass*gxc
    • My Pics Page
« Reply #16 on: January 11, 2008, 05:53:28 PM »
It would look too clean.   ;)   This one will work for the time being but I am going to do more to it in the future.  Now I just want it to run so I can run this beast and see what all the hype about all these old hondas.   ;D
« Reply #17 on: January 11, 2008, 06:34:40 PM »
I am betting if you weigh more that 150 lbs it will flatten out within 20 minutes..
 and unless you put something thicker than that under it, it may put a hole in your battery..
I think they had a hinge on the front of sprung saddles for over a hundred tears for a reason..
Offline Joel
« Reply #18 on: January 11, 2008, 07:41:18 PM »
How thick is the plate?
« Reply #19 on: January 11, 2008, 07:45:27 PM »
1 1/4" x 1/8"
Offline cbass*gxc
    • My Pics Page
« Reply #20 on: January 11, 2008, 10:32:38 PM »
I do only weigh about 160.   ;D  We will see.  If it doesnt work then I will have to get one of the hinged ones.
Offline MoTo-BunnY
  • The 'Torque 'er Down 'till it Strips Then Back 'er Off a Quarter Turn', Type of
  • 1973 CB500 ~ member #3791
    • http://instagram.com/moto_bunny#
« Reply #21 on: January 12, 2008, 01:29:09 AM »
What about a gate hinge - something like this?  lol
found at: http://shop1.mailordercentral.com/marshfasteners/products.asp?dept=463 (note that its stainless steel, too)
maybe too jenky? - but at least its not a C-note and then some like the other hinge! .  ...   ;D
---> instagram.com/moto_bunny# <---
[img width= height=]http://farm4.static.flickr.com/3440/3846213109_ae572002d4_o.gif[/img]
hoppin' on down the bunny trail . . .
1973 Honda CB500K2
1970 Ding-How aka Nova R-S w/3.5HP Tecumseh MiniBike
1970 Taco Model 22 deluxe w/3.0HP Briggs & Stratton MiniBike
1973 GMC Vandura 3/4 Ton Van (350CID V8)
1973 Dodge "Chinook" RV (360CID V8)
1985 Toyota Tercel Wagon SR5 (4WD - 3A engine)
1982 Toyota Pickup Truck (2WD - 22R engine)
1962? DriveX Pack-Mule (Tote-Gote clone)
1989 VW Jetta GLi 16V
1991 Diamondback Mtn. Bike
« Reply #22 on: January 12, 2008, 08:30:12 AM »
There is hinge part that goes on the set on ebay for under 12.00 shipped.. just make the povot part for the front out of a chunk of aluminum.. if you have a drill and a hacksaw and file..
