You are far better off using brake assembly fluid rather than brake fluid.
Glycol based fluid is hygroscopic, meaning is absorbs water, and it will do so from the humidity in the air. The rubber bits that straddle the line between containment and atmosphere, need to NOT have brake fluid exposed to atmosphere as that invites corrosion.
Assembly fluid, while acting as a lube, dissolves readily in brake fluid on the containment side, yet does not attract water on the atmospheric side.
Assembly fluid can be hard to find these days, though. Raybestos makes a lubricant called BAF-12 Hydraulic Brake Cylinder Assembly Fluid that contains a polyalkylene oil and rust inhibitors.
