Author Topic: Tach Cable Seal Leaks - One More Time....  (Read 3505 times)
Offline mark
« on: January 06, 2008, 09:28:45 PM »
Sure enough... these darn things leak. My bike, the parts bike, and a spare top end - all 3 dripping from the tach cable.
I just read through a number of threads on this subject, and believe that I have finally found the problem.
OK... a couple of problems. (a) 30+ year old rubber seal hard as a rock and just plain worn out...... BY..... (b) a shaft which could double as a file.
At left - a chainsaw file. Center - stock shaft. Right - shaft with sealing area polished.
My photo, unfortunately, does not do justice to how truly raspy the stock shaft is - where the oil seal rides.
The seal runs on the rough part between the flat end and the bearing surface.
I spent about 5 minutes with small bits of 320, 600, 1500 grit wetsand paper to make the sealing part of the shaft nice and smooth and shiny.
An original replacement seal and a new o-ring for the holder complete the job.
It took longer to take the pic and type this than it did to fix the problem.
Happy trails.
F you mark...... F you.
Offline mustangcar
Re: Tach Cable Seal Leaks - One More Time....
« Reply #1 on: January 08, 2008, 02:29:38 PM »
thanks for the polishing tip,every tip is much appreciated,will get around to wetsanding it with 2000 grit sandpaper,i guess this is wise with anything that spins around and rides on a rubber seal
Offline Johnie
« Reply #2 on: January 16, 2008, 03:39:53 PM »
I have noted some guys have trouble getting the new tach oil seal in place.  I replaced my entire tach cable and cut the old end off.  Now I use it to install the new oil seal.  Works like it was made for that purpose.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
