Author Topic: hooking up a "modern" regulator/rectifier *need help fast!!! please!*  (Read 6660 times)
This place has gotten good reviews on this site.  No personal experience, though.
http://www.oregonmotorcycleparts.com/Reg_rec_units.html
Offline .RJ
  • homebase in your airspace
Ouch - pricey.
I gotta think about that one - thanks for the link!
Edit - this may do - its from a CB900F
« Last Edit: May 09, 2007, 04:05:05 PM by .RJ »
Ouch - pricey.
Yeah, that's kinda what I thought, too.  Probably, why I keep using the original types I suppose.  I really haven't looked much for replacements.  The original stuff is still working fine in all my bikes.
Offline Pinhead
  • 1979 CB652-ST
Hey, TwoTired: What do you think of the regulator/rectifier in my sig?
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline oldfart
    • The Motorcycle Project
white wire from the alternator - whats its purpose, and will this prevent me from using the modern piece?
The white wire provides voltage to the alternator to energize the electromagnet.
It looks like your F4i has a permanent magnet which has no control.  I don't expect the "new" one you've chosen will work with the SOHC4. Sorry.
In simpler terms, you cannot wire a reg/rect designed for a permanent magent alternator to a system having an electromagnet alternator, or visa-versa.  There just isn't any way, because the regulator portion is activated in a totally different manner.  The permanent magnet type regulator actually shorts the stator to control charge, while the electromagnet type regulator turns on and off the alternator's electromagnet.  Very different systems.  For reference, there are very few bikes made today with the older electromagnet design.  Probably 95 percent are permanent magnet now.   :)  P.S. Yes, the 900F one will work on an SOHC 750, but the color codes won't match even though both are Honda, because when Honda went solid state in the late 70s they moved the regulator from the positive side of the field coil to the negative side, hence the regulator has differing wire colors.
Mike Nixon
Why is there never enough time to do it right, but always enough time to do it over?
www.motorcycleproject.com
I don't know. Never tried it.  The web pointer shows it at almost $50.   It would be more interesting at $16.
All my mechanical regulators are still working without any additional expenditures.  And, I have spares on hand that will fit right on the bike without any adaptors or mount issues.  I simply don't have much incentive to try it out.  Sorry!
Try this attachment
Offline .RJ
Will I need to do any additional work, other than getting a CB900 wiring diagram and matching up the wires?  I'm building my own harness here, so thats not much of a concern.  The harness that came with the bike looks more like a fire hazard than an electrical harness.
Offline oldfart
All the wires are there, you just need to know which are the right ones.   :)  The following link should help.
Mike Nixon
Offline Pinhead
  • 1979 CB652-ST
Holy smokes! It's still ~$13 here at zip 66212!
Doug
:D
I didn't give the site my zip code as I recall.  (but maybe, I did) mine's 95035
Partsamerica.com  Free shipping over $50
Part number VR301
Retail Price:   $72.57
Our Price:   $47.99
You Save:   $24.58
Offline Pinhead
  • 1979 CB652-ST
Holy cow,  you're right! I put in your zipcode and it came up to $47.99. What a crock of horse#$%*!! It's the exact same part that I get for $12.96!!!
Doug
:D
