Author Topic: modified swingarm  (Read 2310 times)
Offline bert96
  • past ride
modified swingarm
« on: January 10, 2008, 07:16:54 AM »
 Is one of you have ever modified a swingarm(cb750) to accept shocks with eye on bottom instead
of clevis?
I found a pretty good deal on shocks but that's my only problem there's eyes on both end :(
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Re: modified swingarm
« Reply #1 on: January 10, 2008, 08:49:12 PM »
No but it would be relatively easy. I would study a few mounts on other arms and try to build similar  mounts..
 You will have a great selection of shocks then....
Offline Geeto67
  • A grumpy
« Reply #2 on: January 10, 2008, 09:39:27 PM »
I am not so sure. Any mfg that still makes shocks for old twin shock bikes makes both clevis end and eyelet shocks. Plenty of bikes use clevis end shocks (DOHC hondas, GS series Suzukis, etc).
Clevis end shocks are still relativley easy to get a hold of, and there are still twin shock bikes made today that use clevis ended shocks. If you check the yahoo japan auctions you will see a lot of new cheap shocks with clevis ends.
Works, Hagon, Ikon, Boge, Ohlins all make clevis ended shocks just to name a few.
Maintenance Matters Most
Offline bert96
  • past ride
« Reply #3 on: January 11, 2008, 05:32:41 AM »
 Oh! ok,i will take a look at this auction.
This what i would like to install(monza cafe model)
http://www.mikesxs.net/mikesxs-suspension.php?category_id=6.1
Offline bert96
  • past ride
« Reply #4 on: January 11, 2008, 06:15:50 AM »
 I can't see anyting on yahoo auction,the only thing i see is a lot of little squares side by side :(
Offline Pip
  • Post Goblin
« Reply #5 on: January 11, 2008, 06:51:05 AM »
Those little boxes are the Japanese characters your computer doesn't recognize.
2005 Ducati Monster 620.
1976 Honda CB250G5 Cafe/Resto.
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #6 on: January 11, 2008, 07:33:52 AM »
I did it...have gl1100 air shocks on my CB750F...fairly straight forward...just a couple of tack welds on my original mounts, grind em off.  weld on new brackets....just a hint...make sure that the new bracket sits flush against the inside edge of axle plate on swingarm.....otherwise left side shock gets into the chain guard...I am minus one orginal chrome F chain Guard.  Matt
MATT
« Reply #7 on: January 11, 2008, 08:23:54 AM »
Doing this also lets you have the option of running other lengths as you can put the new bracket where you see fit..sometimes being able to go back to original or change back and forth..
« Last Edit: January 11, 2008, 06:18:14 PM by 754 »
Jbird
« Reply #8 on: January 11, 2008, 09:34:51 AM »
I'd just build an H shaped steel bracket, bolt it to the swing arm and bolt the shock to it. It would be laid down and your lower shock mount would be an inch or so rearwards.
 Jbird 8)
« Reply #9 on: January 11, 2008, 06:17:30 PM »
What are you going to bolt it to?? the chain adjuster??
Jbird
« Reply #10 on: January 11, 2008, 06:42:30 PM »
Bolt it to the original shock mount on the swing arm. Kind of like lowering blocks for a shock with a eye. All the bolts on that end of the shock would still be in a double shear configuration.  Jbird 8)
Offline bert96
  • past ride
« Reply #11 on: January 12, 2008, 05:51:31 AM »
 Check these shocks,every set should be like that,clevis or eyes at the end you have the choice!
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=024&sspagename=STRK%3AMEWA%3APIC&viewitem=&item=370012708625&rd=1
Offline bert96
  • past ride
« Reply #12 on: January 12, 2008, 06:44:40 AM »
 I would like to know either but they look really well made from the pictures.
