Author Topic: Picked up a new bike today  (Read 4241 times)
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« on: January 12, 2008, 01:15:11 PM »
'79 KZ650.
Quick bike. Rode it the 40 miles home.
Kerker exhaust, kinda rough cosmetically, but all there.
Very solid bike, stability wise.
Engine and carbs need to be gone through, idles high and stumbles at low rpm. Screams at high RPM.
Pictures coming soon.
Will let you know if it's faster than my K0 once I fix the K0 :/
/edit
Heres the craigslist photos
« Last Edit: January 12, 2008, 02:22:24 PM by mlinder »
No.
Offline azuredesign
  • Knupping pin
Re: Picked up a new bike today
« Reply #1 on: January 12, 2008, 03:16:21 PM »
Nice lines and looks like it'll clean up with a bit o'elbow grease.
Congrats!
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #2 on: January 12, 2008, 03:20:31 PM »
Congrats!
Thanks.
Not bad for 500 smackers, considering I rode it home. New tires, new-ish battery, new ignition, new stator, too.
There is a fair bit of rust, tank will need to have a dent removed and painted. Electrics are a bit messy, and needs a new headlamp basket.
Still, not bad for a runner.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #3 on: January 12, 2008, 07:53:44 PM »
Just went through the carbs. they look ok. Havent worked on carbs with an accelerator pump before though.
Found it has dyna 3 ohm coils and a dyna-s ignition. Was happy about that. Lots of water in the master cylinder. Braided steel brake lines.
Gonna be a cool little bike.
No.
Offline mrblasty
  • Expertly
« Reply #4 on: January 13, 2008, 07:36:38 AM »
Cool looking bike.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
« Reply #5 on: January 13, 2008, 08:29:04 AM »
Nice looking bike and I like the lines on the back end. What are you planning on doing with it?
Good deal!
cheers
Andy
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #6 on: January 13, 2008, 09:58:20 AM »
Going to lose the back fender, bob the front fender, get a different seat, paint it silver with red pinstriping, put on drag bars, and get everything in good working order.
Then I'll ride it till I Sell it.
No.
« Reply #7 on: January 13, 2008, 02:16:27 PM »
Mlinder Id be interested in seeing the finished product - sounds like a good project.
cheers
Andy
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #8 on: January 14, 2008, 02:21:52 PM »
cheers
Andy
Have it mostly torn down. Have made a shopping list for replacement parts. Will take some pics, so we can see progress. You can see them, too. :)
« Last Edit: January 14, 2008, 02:23:28 PM by mlinder »
No.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #9 on: January 14, 2008, 02:52:12 PM »
       Hey Mark, Kinda running behind on seeing your latest acquisition. Nice looking bike there, especially for the money. Looking forward to your progress to Sounds like you've got a plan of attack on it too. The 650 Kawas are pretty good runners and pretty good lookers too! 8) ;)
                                  Later on, Bill :) ;)
Member # 1969
Offline SEBNN
« Reply #10 on: January 26, 2008, 03:08:07 PM »
Where are you going for the carb parts?  I am into my elbows in a set of 79 kz650 carbs and having some trouble trying to find a kit that will fit.  Looks like yours is a better start than mine, mine needed the carbs gone through completely and new carb holders just to even think of it running.  Parts on order for most of it.  Anyways, I would be interested in seeing how it turns out when you are done.
Offline Killer Canary
  • Typical Bran Muffin
« Reply #11 on: January 26, 2008, 04:15:30 PM »
Check that the bolt holding the bellcrank to the throttle shaft is tight.Idle problems could also be caused by a pinhole in the vacuum switch diaphragm.
Assume that the valves have never been shimmed and are way out of range; leave yourself a month for that job.
I love/hate mine; 150 psi per cylinder, goes like crazy, uses more oil than gas.
Now that I've discovered CB 350 twins...
Kawi GPz900, H1
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #12 on: February 04, 2008, 10:16:35 AM »
Valves done.
aluminum bits polished.
oil and filter changed.
new head gasket.
Carbs rejetted, velocity stacks installed.
New throttle and clutch cable installed.
new 15/42 sprockets and chain installed.
Most bolts replaced with stainless allen bolts.
tach and speedo housing sand blasted and ready for paint
new drag bars installed.
Fork oil changed
everything lubed
aluminum bullet blinkers
New master cylinder
Fixed cam chain tensioner
Brakes rebuilt, steel braided lines
Left to do:
Bob front fender
Lose rear fender
Prep, Fill, Paint and pinstripe tank and bodywork, front fender and headlamp ears
Paint headers
Polish fork lowers
Clean up wheels
Paint various crap satin black
modify idiot lamp tree to something more svelte, polish aluminum
Find some mirrors I like?
Polish up muffler
New glass for speedo
Cut and upholster the seat
Ride the piss out of it
Things the bike came with:
New tires
Dyna S
Dyna 3ohm coils
dyna plug wires
Progressive suspension
K&N Filter (not being used)
4 into 1 exhaust
It's coming along nicely.
Paint will probably take the longest.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #13 on: February 04, 2008, 10:28:50 AM »
Z1 enterprises, eh?
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #14 on: February 04, 2008, 10:39:09 AM »
This one doesn't seem to burn any oil.
Haven't done a compression test, probably wont unless I see some anomalies.
I figured out the idle issue.
The battery was dead, and of course the generator doesn't make enough enough power under 2 grand to keep things running without a battery.
No.
Offline dusterdude
« Reply #15 on: February 04, 2008, 10:41:01 AM »
z1 is where i got kits for my kz750.they are k and l kits,real nice.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline SEBNN
« Reply #16 on: February 04, 2008, 07:46:03 PM »
I've been looking at z1, but evidentially no one carries the kits for the pumper model 650.  Might have to find a set of non-pump carbs.  Hope that there isn't a performance issue between them.  Thanks for the advice.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #17 on: February 04, 2008, 07:52:44 PM »
I do believe the carbs are the same, but for the accel pump gaskets and diaphragms. Call up Z1, they'll be happy to help.
No.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #18 on: March 17, 2008, 10:47:48 AM »
She Rides.
Well, took her out for her maiden ride yesterday.
Adjusted valves, synched carbs. Got the cam chain tensioner working correctly.
It's a great bike.
The mid range is positively fantastic.
The accel pump makes a world of difference over regular slide carbs, and still has the great feel of slide carbs over CV carbs.
What's been done and what it has:
I've gone one smaller tooth than stock on the countersprocket.
New chain and rear sprocket.
Valves adjusted.
Aluminum velocity stacks
22.5 pilot jets, 120 mains
4 into 1 exhaust
carbs synched
dyna s ignition
dyna 3.0 ohm coils
removed airbox
Removed centerstand
cut down rear fender
drag bars
progressive suspension all around
rebuilt brakes (with stainless hoses). This thing stops GREAT.
Dunlop tires.
New throttle and clutch cable (ditched the return cable)
I'm really impressed with this bike.
It's surefooted and powerful in many ways that other classic bikes aren't. The frame is, relatively speaking, very stiff.
It revs very quickly. Found myself saying '#$%*, I'm already at 10, I shoulda shifted half a second ago.'
It's still not as powerful at the top of the rev range is my cb750, but it really doesn't matter.
The shifter is really nice
All thats left is cosmetic crap. Start on that next weekend, I suppose.
If I'm not too busy riding it.
(yes, I know I need to shave.)
We are going to go with a dark silver metallic, with either dark red or white pinstripes.
Getting rid of the rear taillight  altogether, and using dual filament aluminum bullet blinkers to handle both turning and brake light.
Needs a new seat, obviously.
I'll be filling and painting the gauges, or we were thinking about a small, electronic instrument cluster.
Need to polish the front brake caliper (its' been stripped) and the tripple trees.
Wrapping the headers and cleaning up that can.
Clean up the engine a bit (already polished the valve cover.)
No.
« Reply #19 on: March 17, 2008, 11:14:38 AM »
Nice bike! Too bad you are going to paint over that classic orange colour but hey thats progress I guess  ;). Thanks for the photos - always good to see a ride on a bike -gives it more perspective.
Have fun -sounds like you are going to!
cheers
Andy
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #20 on: March 17, 2008, 11:16:12 AM »
Andy, the orange paint is pretty thrashed, and the tank has some minor dents.
'Course, I could always paint it orange again.
No.
Offline bill440cars
« Reply #21 on: March 17, 2008, 11:45:07 AM »
         Hey Mark.  Doesn't look like a bad looking bike from a distance. Looks like it has lots of potential! 8)
         BTW, facial hair situation that you do (wife used to like it, but now would like me to shave it off. ::) Oh, and mine is gray though. ;D
                                    Take care, Bill :) ;)
Member # 1969
« Reply #22 on: March 17, 2008, 12:01:56 PM »
Im sure you are going to do a good job on the new paint - look forward to seeing it. I like the shape of those tanks.
cheers
Andy
Offline prosolar
  • I've seen things that would make you shit out a book about puking
« Reply #23 on: March 17, 2008, 03:12:41 PM »
Hey Mark, don't I get any credit? ;D
69' CB750
75' CB550K
78' CB550K
79' KZ650
82' GS1100G
04' Bandit 1200S
Many others
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #24 on: March 17, 2008, 03:21:07 PM »
Oh hells no, Marcus..
People, say hello to Marcus, they other owner of the kz650.
Smells bad, but a damned fine mechanic.
Thats his little ol' CB 350 in the picture.
As you can see, he looks a bit of a circus clown on it :P
Marcus, glad to see you on the board.
 (his GF has a really nice cb500, too.)
No.
