Author Topic: Know any thing about rubber mounted sprocket,,,, more Morris Mag ??  (Read 1932 times)
Offline Gregorymoto
  • SOHC Aficionado
this is some more info on the morris mag that i'm trying to sort out.
The rear sprocket is rubber mounted using bushings that fit over the mounting bolt into over sized hole's on the sprocket.
Any info on this. What bike used this.
I'v been around bikes and a shop my whole life and have never found this on any other Rim.
My guess is that it is there to take the snap force away from the Alum hub insert.
I'l spec the sprocket latter and post it and see if it rings a bell.
Yep, i have issues with this sort of stuff.
Re: Know any thing about rubber mounted sprocket,,,, more Morris Mag ??
« Reply #1 on: January 16, 2008, 08:04:45 AM »
Its a Morris cush drive..set of beer colored urethane bushings with a steel sleeve.. goes in about a 7/8 hole on the sprocket on the bolt circle.
What may or may not be there but should, is a pair of metal plates, one goes on eac side to prevent sproket from going sideways.
I got this setup in my toolbox!
Offline dusterdude
« Reply #2 on: January 16, 2008, 08:59:37 AM »
wow,when he said morris mag i thought he was talking about a magneto.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #3 on: January 16, 2008, 09:02:57 AM »
Hah.. had one of them too..
Offline Gregorymoto
  • SOHC Aficionado
« Reply #4 on: January 16, 2008, 09:29:02 AM »
Hay 754, ya i have the paltes as well. Is you sproket a 6 hole mount.
I'm having issue finding a replacement.
« Reply #5 on: January 16, 2008, 10:00:50 AM »
I just have a kit, I think who I got it from used the sprocket. It was on a skinny 18 Inch rear that I still have.
Get a blank and machine it or send your specs in to the sprocket maker.. might be easier to get 2 differnt tooth count sprockets so you have gearing choises.
Offline Gregorymoto
  • SOHC Aficionado
« Reply #6 on: January 16, 2008, 10:05:49 AM »
Thanks
Offline City Boy
« Reply #7 on: January 16, 2008, 12:19:18 PM »
My .02$.I have Morris alum. mags on my unit.It came with the cush drive.One day cruising on a city street,I rolled off the throttle and all the sprocket bolts snapped.Cushions I think were a little soft and allowed too much side load on bolts.Anyway,I drilled and tapped the holes for3/8" bolts,deep sixed the cush drive,and countersunk the holes in a new sprocket ,and used 3/8" countersunk bolts.Works fine,looks good,and has survived muchos high load miles with no problems,and I like the more positive feel too.
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline 736cc
« Reply #8 on: January 16, 2008, 12:20:50 PM »
 Sprocket Specialists still carries the unique bushing kit for Morris Mag rear wheel, replaced my rear sprocket this past summer w/ the kit.
« Last Edit: January 16, 2008, 12:24:33 PM by 736cc »
Rocking-M
« Reply #9 on: January 18, 2008, 05:10:25 AM »
If you need a sprocket made check out Rebel Gear.
http://www.rebelgears.com/testimonials.html
Offline 736cc
« Reply #10 on: January 18, 2008, 05:36:56 AM »
 Sprocket Specialists has the sprocket and bushing kits, any size chain and teeth
Offline Gregorymoto
  • SOHC Aficionado
« Reply #11 on: January 20, 2008, 06:39:23 PM »
Hay DG, ya man that is the one.
I just put in an order for one.
Thanx for the effort
Offline Gregorymoto
  • SOHC Aficionado
« Reply #12 on: January 20, 2008, 07:06:10 PM »
Does any one know the part number, i ordered one Fri from Sprocket Specialest using a CAD drawing for the bolt pattern.
If not no big i can call them tomorrow.
Hay thanks for the info guy's. Iv'e been away from the SOHC association for the last 3 years while in grad school.
Its nice to be back .
G. Mountain
