Author Topic: Starter button  (Read 5627 times)
smokeygold
Starter button
« on: January 18, 2008, 09:48:43 PM »
Any idea where I can get the little electric starter button without purchasing the entire switch assy. The little push button is gone. Starter still works if you put something in to push the inside piece. 75 Cb 550
Offline bert96
  • past ride
Re: Starter button
« Reply #1 on: January 19, 2008, 02:52:44 AM »
 Look at this site,check in "ELEKTRIK" section
http://www.four-shop.de/
I know there is other places who sell this button but i can't remember right now.
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline bert96
  • past ride
Re: Starter button
« Reply #2 on: January 19, 2008, 02:59:01 AM »
Offline Peterbylt
Re: Starter button
« Reply #3 on: January 19, 2008, 04:39:03 AM »
My starter button desintegrated about a year ago. I replaced the button with one from radioshack.
The button is still working with no issues.
Here is the link to the thread I posted with pictures.
http://forums.sohc4.net/index.php?topic=12586.msg120462#msg120462
Peter
1975 550F SuperSport
1975 GL1000 Goldwing
1979 CM400A Hondamatic
1981 GL1100 Goldwing
1985 CMX250C Rebel
Offline nippon
    • Classic Cycle City
Re: Starter button
« Reply #4 on: January 19, 2008, 05:26:33 AM »
CMSNL.com
Offline Jonesy
  • Shop Rat
Re: Starter button
« Reply #5 on: January 19, 2008, 06:15:21 AM »
I boughe one from partsnmore and they are a spot-on match to the original.
Timrek
Re: Starter button
« Reply #6 on: February 19, 2010, 06:45:02 PM »
 I found it!
Right there.
https://www.partsnmore.com/cat_index.php?model=cb750_sohc&category=electrical
It's cheaper too! ;)
Any place else carry these? Parts n more requires a $35 minimum order.
Re: Starter button
« Reply #7 on: February 19, 2010, 07:28:27 PM »
They are a generic part from any Jap bike. Mine is from a Kawi.
Offline KRONUS0100
  • MAD MATT THE MANIAC
Re: Starter button
« Reply #8 on: February 19, 2010, 07:52:12 PM »
I HAVE USED THE BUTTON FROM RADIO SHACK....SAME BUTTON AVAILABLE FROM ALLELECTRONICS.COM
MATT
Timrek
Re: Starter button
« Reply #9 on: February 21, 2010, 08:28:45 PM »
Did you just get one off a used bike or get a replacement from a dealer or web site?
Did you just put in a new hidden switch or use one to replace the button in the handlebar mounted switch?
If you replaced the one in the handlebar switch can you give me an idea of the part # from ALLELECTRONICS.COM?
Does any one know if this part, ie just the botton, is a part I can get from the dealer?
Re: Starter button
« Reply #10 on: February 21, 2010, 09:42:46 PM »
If the 75 has the headlight on all the time and it goes out when you press the starter the button can not be got on its own you have to but the complete switch, the button on its own is for the earlier bikes and it works like the horn button (same part number) that grounds to the bars
Re: Starter button
« Reply #11 on: February 22, 2010, 06:56:04 AM »
If you are just talking about the little plastic button and not the entire switch.
Timrek
Re: Starter button
« Reply #12 on: February 22, 2010, 10:05:38 AM »
Does any one know if this part, ie just the button, is a part I can get from the dealer?
I have a 1976 CB750 K6. I got the bike in a non running state and I am still working on getting it running. Just and FYI to all.
I am looking to replace just the little plastic button not the entire switch. As far as I know the rest of the switch works fine it is just missing the little plastic button. It has a separate switch for hi / low for the headlight and horn on the left side.
Re: Starter button
« Reply #13 on: February 22, 2010, 10:25:33 AM »
Good luck but I think Bryan J got it right. On my K0 I used a horn button, contact and spring on my 75F I had to buy the entire control. Take it apart, it will most likely be in pieces. I temp wired a starter button until the new part came in. A little tricky but can be done.
Offline Bodi
Re: Starter button
« Reply #14 on: February 23, 2010, 07:48:43 AM »
Don't assume the rest of the switch is OK.
The headlight power does go through this switch, turning it off (presumably to reduce power draw) when starting. The internal parts on original switches have generally disintegrated, and the likely reason for the missing button is that a PO opened the switch pod to see why the switch wasn't working... whereupon parts whizzed around the room. Bypassing the headlight defeat is easy, and the bike runs fine without electric start. There are many SOHC4 bikes running like that!
Timrek
Re: Starter button
« Reply #15 on: February 23, 2010, 05:31:16 PM »
Until I get the thing running I am not assuming that anything on the bike works or is OK. It has been sitting since 1986. The guy I got it from said the button broke on him but was working it happened. I have been looking at right switches on ebay. Maybe I can "harvest" the button off the horn and use it on the starter. It seems like the left hand switch is REALLY hard to find intact.
Well wish me luck all this is my first bike and I am learning as I am going. Thank you all for your help. I may be just getting 6 of the buttons from parts n more and selling the other 5 on ebay.
Re: Starter button
« Reply #16 on: February 23, 2010, 06:39:41 PM »
I just replaced my entire right hand assy on my '76 550F, apparently those buttons only last 30 something years!
Re: Starter button
« Reply #17 on: March 01, 2010, 11:19:43 PM »
If its a 76 the horn button IS NOT THE SAME the RH switch sterter button only comes with the complete switch as it works the solenoid different AND turns the headlamp OFF when starting
