Author Topic: Concrete Laundry Tubs  (Read 12323 times)
Offline Bob Wessner
  • "Carbs Suck!"
« on: January 24, 2008, 03:25:38 PM »
Getting ready to tackle an overdue home project. Replace the laundry tub and do some re-plumbing. The old laundry tub (double >:() is concrete, house is 65 yrs old. The only way I will get it out is break it up. Can anyone tell me if it is reinforced in some way (i.e. thin rods, mesh, etc.)? Just want to have everything I need handy when I start.
Offline UnCrash
  • Pass
    • My Blog
Re: Concrete Laundry Tubs
« Reply #1 on: January 24, 2008, 03:47:51 PM »
I usually start projects like that with a 6 pack of ambition for company  ;)
Offline mgmuellner
« Reply #2 on: January 24, 2008, 04:00:47 PM »
And a BFH.
I'd expect it'd be reinforced & if it's not feel a little lucky.
73 CB750
69 CB350
73 RD350
73 z50 (2 of em)
01 SV650
Offline Jonesy
  • Shop Rat
« Reply #3 on: January 24, 2008, 04:17:52 PM »
Why do you want to get rid of it.. Some people would kill to have one of those...
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #4 on: January 24, 2008, 04:19:45 PM »
Come and get it Dan, it's all yours. ;D
Too big, have limited space in the laundry area after we refinished half the basement and I want to rearrange things slightly.
« Reply #5 on: January 24, 2008, 04:45:34 PM »
Chances are it is simply cast concrete with no metal. It is probably brittle, so if you whack it in the right spots you can get big chunks out of it. Try to crack it in half first.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #6 on: January 24, 2008, 04:49:38 PM »
That was the plan, cozy up to my favorite sledge.
« Reply #7 on: January 24, 2008, 05:22:05 PM »
What the hecks a concrete laundry tub ?
Sam. ;)
Offline 333
  • Time for change
« Reply #8 on: January 24, 2008, 06:07:46 PM »
Sam. ;)
Youngster!
I'll bet that if you could get it out in one piece, set it on the curb, and it will be gone by the next morning!
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline mrblasty
  • Expertly
« Reply #9 on: January 24, 2008, 06:13:07 PM »
Getting one of those out of the basement in one piece is a hernia waiting to happen, I suggest smashing it over a tarp, that way way if you inner hatchet murderer overtakes you it's much easier to clean up.
I farted and made my son cry.
1973 Honda CB 750
1975 GL 1000
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: January 24, 2008, 06:13:32 PM »
That will never happen, the thing has to weigh as much as I do. :o
« Reply #11 on: January 24, 2008, 06:15:58 PM »
Is yours floor mounted or wall mounted?
Many sinks fit onto posts or heads with a wedged slot, if mounted to a wall.  Usually gravity and the friction of the wedged slot is all that keeps it there.
If wall mounted, jack it off the moorings from under and near the wall.  Cushion with a woodblock.  Once it is raised clear of the wedge slot, it should come off quickly.  Remove hook ups first, of course.
I don't understand why breaking it up is the best approach.  Sounds pretty messy and amature-ish.
Of course, many situations are unique.  I haven't seen yours, so who knows?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #12 on: January 24, 2008, 06:20:06 PM »
It's free standing and sits on a steel frame. Trust me, breaking it up is about the only way. I must weigh in excess of 200# easily, is long, tight corners and turns and a steep flight of stairs. Really no point in trying to salvage it anyway, they have been code violations here in Ann Arbor for a good many years.
Offline mark
« Reply #13 on: January 24, 2008, 06:20:59 PM »
Sam. ;)
Youngster!
I reckon some o' them furriners jest aint familiar with good ol' Yankee plumbing. It's a concrete box about the size of a short fat guy's coffin, usually divided in two. Weighs about as much as a Buick.
Getting it out in one piece would be a neat trick... maybe the basement has a big picture window?
Ours was right by the back door... getting it from there to the driveway 10 feet away was hell.
Sledge time...
F you mark...... F you.
Rocking-M
« Reply #14 on: January 24, 2008, 06:23:46 PM »
I suspect Brits are smart enough not to have basements.
We didn't have basements in SE NC either, if you did it just let the
swamp in. ;)
Took me a while to figure out what a concrete laundry tub was to. ;D ;D
Offline Jonesy
  • Shop Rat
« Reply #15 on: January 24, 2008, 06:27:59 PM »
Already have one... sorry.
Since it's a code violation and you're pressed for space, that's good enough justification for me...
Need a hand? (you could give 1-800-GOT-JUNK a call. A buddy had them remove a steel bathtub from his old house and they took care of everything. I doubt your garbage collectors will haul it away, will they?)
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #16 on: January 24, 2008, 06:35:59 PM »
Hmm, might consider 1-800-Got-Junk, it appeals to the "lazy" in me. ;D Garbage would take it if I fed it in pieces into the trash bin. They use automated trucks now, but there is a 200# or so total weight limit.
Offline 333
  • Time for change
« Reply #17 on: January 24, 2008, 06:41:40 PM »
If you get it out in one piece, you won't have to pay to dispose it.  I'm tellin' you code violation or not, somebody will kill for it.
Offline Jonesy
  • Shop Rat
« Reply #18 on: January 24, 2008, 06:49:46 PM »
Wouldn't hurt to give them a call and see if they'd do it and what they'd charge.
Offline 736cc
« Reply #19 on: January 24, 2008, 07:05:01 PM »
  C'mon guys, THINK HARDER! Put it on ebay and have the buyer remove it. Use profits to buy parts for your K0. ;)
« Last Edit: January 24, 2008, 07:06:41 PM by 736cc »
Offline Uncle Ernie
« Reply #20 on: January 24, 2008, 07:45:46 PM »
Dealers here will give you $25 or $50 for it and get it out,
Take it to their shop and ask $150 to $200 for it.  And the rustier-looking, the better.
« Reply #21 on: January 24, 2008, 08:08:45 PM »
I know what you are on about now, we used to call them stone sinks.
I didn't realise it was an old thing...never saw any when I lived over there.
When I was a youngster we had one. We also had a coal fired boiler.
It was a brick built thing in a corner of the wash room with a brick stack going up the inside wall.
It had a big copper couldron set into it for boiling your whites.
Mum used to fill it with water then put paper and kindling wood under the boiler.
All she had to do then was rub two pieces of wood together for about 1 hour and the fire would be lit. ;D ;D ;D ;D ;D
Sam. ::) ::) ::)
« Reply #22 on: January 24, 2008, 08:57:33 PM »
what is a "laundry" ????? ???
Offline 333
  • Time for change
« Reply #23 on: January 24, 2008, 09:00:55 PM »
754, do people call you "stinky" or something like that?
« Reply #24 on: January 24, 2008, 09:05:38 PM »
How did you wash on the salt ;D ;D ;D ;D ;D
