I have a 78 CB550K, the float level is supposed to be 12.5mm...I set it to 12.5 using a float gauge with the carbs upside down on the table. I double checked this when I installed the carbs, I did the clear tube test on carb #1 - I put some clear fuel line on the drain valve and opened the drain screw. The fuel level is 16-17mm below the top of the bowl...
So, my question is, is the fuel level supposed to be at the top of the bowl or is it supposed to be 12.5mm from the top? Or is this not a reliable way to check? The bike starts easily and runs smooth although it seems to not have much power for a 550 (due to leanness maybe?)...oh and BTW the jets are #105s, installed by a PO, not sure if that has anything to do with it. I think he may have overcompensated on the mixture, the stock setting for #90s is 1.5 turns, he's got them at 3.5 turns...
mossen
