I have not decided what I am going to do about the charging system as of yet.
so far I have the throttle bodies which i picked up for $50.00 shipped
and I have an MSD external in-line fuel pump on its way for $95.00 shipped.
next up is the regulator, and Microsquirt EFI controller.
I currently have the throttle bodies apart for re-spacing and moving the throttle linkage to the center. I have already removed the electronically controlled Choke motor, butterfly's, and bearings. I am gonna pick up some JB weld later tonight and finish the removal of the e-choke system. I also need to pick up some 6mm threaded rod and some aluminum spacers.
All in all, I will be right around the cost of a pair of brand new CR carbs and will not have to deal with re-jetting and the down falls of the CR-carbs on the street like over sooting the plugs and running rich at low speeds.
