Author Topic: Front fender question  (Read 780 times)
kev79
« on: February 08, 2008, 11:00:58 AM »
I have heard if you remove the stock front fender and take the fender braces off it will cause a wobble and the front end will flex. I wanted to replace the stock front fender with a fiberglass one. Is there anyway to do this without using the fender bracing?
eldar
Re: Front fender question
« Reply #1 on: February 08, 2008, 11:03:12 AM »
Some here do it and do not mind the bit of flex. If you are putting on a fiberglass fender, you might want to brace it to help prevent cracking.
